stumped on valve cover gasket leak.
Old Jan 9, 2012 | 11:11 AM
DelsolVted's Avatar
Default stumped on valve cover gasket leak.
i replaced the gasket and it leaked alot and then upon inspection i had a broke a mounting hole in half so i replaced rocker arm assembly and did everything to honda specs and the gasket still leaks but just when car is shut off or on a hill sideways does not leak as bad on level ground. the oil seeps out front pass side of valve cover. has new gaskets and the bolts are snug. what else could i do to stop this leak.?
Old Jan 9, 2012 | 11:17 AM
kaiba's Avatar
Default Re: stumped on valve cover gasket leak.
Did you also use Hondabond and/or RTV Ultra grey?
Old Jan 9, 2012 | 11:20 AM
kyden's Avatar
did you put honda bond near the cam caps as per the service manual? cam seal?
Old Jan 9, 2012 | 11:22 AM
motegicivic's Avatar
Did you put rtv in the corners?
Old Jan 9, 2012 | 11:48 AM
DelsolVted's Avatar
no i did not but its not leaking by the cam caps but in front corner if i was goin to use rtv but was told not to bcuz it was a new gasket.
Old Jan 9, 2012 | 11:50 AM
DelsolVted's Avatar
i have black rtv stuff that ok or do i need ultra grey
Old Jan 9, 2012 | 12:23 PM
According the service manual dab some in the corners, rtv should be fine. Don't go over board.
Old Jan 9, 2012 | 12:28 PM
DelsolVted's Avatar
ok well i did a thin strip and then smoothed it out so and the the cam caps on the gasket cuz it was a tight fit so hopefully this will stop my leaking.
Old Jan 9, 2012 | 12:33 PM
Corners of the U recess I mean. Obviously if you know where it is leaking you can add a little rtv there.
Don't go crazy torquing the cover down.
Old Jan 9, 2012 | 05:57 PM
DelsolVted's Avatar
so what after 3 hours of sitn i go for a drive and it still seeps out.
Old Jan 9, 2012 | 06:46 PM
Wrona's Avatar
i put red rtv on all the cam corners in my cars never had a leak make sure your valvecover is not warped and your head is clean before installing the gasket
Old Jan 11, 2012 | 12:46 PM
DelsolVted's Avatar
seems to be fixed for now plz delete things for the help
Old Jan 11, 2012 | 02:37 PM
Wrona's Avatar
they don't delete threads when they're done they are kept for a reffrance for others when they search
Old Jan 11, 2012 | 03:29 PM
grumblemarc's Avatar
The Grumpiest
Solved!
Squigget
Feb 8, 2020 07:12 PM
Uljima
Oct 16, 2015 01:02 AM
rallyeredem2
Honda Civic (2001 - 2005)
Dec 25, 2014 10:58 AM
davidt1
Apr 4, 2012 06:44 AM
E-spec Tuner
Apr 17, 2003 09:16 AM
