00 Civic EX - Hesitation/Misfire Issues
Old Jan 8, 2012 | 07:55 PM
CRex619's Avatar
Default 00 Civic EX - Hesitation/Misfire Issues
hello ht people have been having a few problems with my Civic lately and I'm not sure what is cause the issue hoping someone would be able to help as I'm not very car inclined, need to learn more though. Issues is I'll be driving down the road and randomly it will act like I'm not pressing the gas. Doesn't bog down or anything just decelerates like you have taken your foot off the pedal. If I take my foot off and put it back on the gas it starts going again. I'm not really sure what is causing the issues so any help would be appreciated.
Car is a 2000 Honda Civic EX D16Y8 161k
Have tried new plugs, wires, and fuel filter.
Thanks again
Old Jan 11, 2012 | 04:24 AM
CRex619's Avatar
Default Re: Hesitation/Misfire Issues
Anyone?
Old Jan 11, 2012 | 05:33 AM
Former User's Avatar
Auto or manual transmission?
Any CEL codes?
Why haven't you also replaced the fuel filter, distributor cap and rotor, and adjusted the ignition timing to spec. Do those things and then go from there, such as testing the TPS.
Old Jan 11, 2012 | 05:43 AM
motegicivic's Avatar
Default Re: 00 Civic EX - Hesitation/Misfire Issues
Def check the TPS. Also check the throttle cable, make sure it is not dirty at the throttle body, and you can move it freely.
Old Jan 11, 2012 | 07:10 AM
CRex619's Avatar
Any CEL codes?
Manual Trans
No CEL codes
Already replaced Fuel Filter. Ill try cap and rotor next not really sure how to adjust ignition timing.
Thanks
Old Jan 11, 2012 | 07:44 AM
Originally Posted by CRex619
Manual Trans
No CEL codes
Thanks
Check the stickies for timing, you need a timing gun.
Old Jan 11, 2012 | 10:09 AM
CRex619's Avatar
Thanks for the info
Hondaman4life66
18
Apr 21, 2018 08:30 AM
lopezchris21
15
Jun 13, 2012 12:25 PM
crxjarred
Jun 10, 2011 03:06 PM
CPTN
May 21, 2011 09:25 PM
crxricer66
Apr 2, 2008 08:47 PM
