Check oil light flickering on my 97 ej6
Old Jan 8, 2012 | 11:52 AM
david420's Avatar
Default Check oil light flickering on my 97 ej6
So recently my oil light has been coming on everytime i go into neutral. It did that for like 2 weeks and now it is flickering and totally random. I was thinking it was wiring but also im thinking that its because i only have 4/5 valve cover bolts making it lose pressure. Any help is much appreciated.
Old Jan 8, 2012 | 11:54 AM
Former User's Avatar
Default Re: Check oil light flickering on my 97 ej6
Is the engine low on oil?
How many miles on the engine?
Old Jan 8, 2012 | 12:03 PM
david420's Avatar
No i check the oil all the time cuz of the light and the engine has about 100,000 miles.
Old Jan 8, 2012 | 12:04 PM
Measure the oil pressure.
Old Jan 8, 2012 | 12:06 PM
david420's Avatar
ok ill try to figure out how to do that, you dont think it would be a wiring problem?
Old Jan 8, 2012 | 12:18 PM
In my opinion, you first need to rule out low oil pressure, as this condition WILL destroy the engine. If pressure is fine, then you obviously troubleshoot the circuit, comforted by the fact that there's no engine risk.
I would stop driving the car until you have measured the pressure.
Old Jan 8, 2012 | 12:25 PM
david420's Avatar
Ok yea i just realized how serious it was. Its been driving fine so i just assumed it was a faulty sensor or something. thanks for the advice
Old Jan 9, 2012 | 06:14 AM
24TEN's Avatar
PHANTOM MENACE
Just reinforcing Ron's advice, similar problem on a car a friend had purchased as a daily. Same condition (flickering light, oil level fine), seller said it's faulty wiring and not to worry. A few months later the engine threw a rod out the front of the block. Don't risk it!!
Old Jan 9, 2012 | 07:16 AM
low91rex's Avatar
does the oil light flicker all the time or does it just flicker when the car is warm and is at idle? That light is called the "dummy" light and it only comes on at around 4-5 psi which is dangerously low.
Like Ron said, I would stop running the car immediately until you can hook up a oil gauge to see exactly what your reading is and go from there.
Things to check if you pressure is indeed low:
- Oil pickup screen
- Oil pump
- Main and rod bearings
Old Jan 9, 2012 | 01:07 PM
david420's Avatar
Yeah that would suck im checking it today, thanks for confirming this for me.
- Oil pickup screen
- Oil pump
It used to only come one when idling then it started flickering randomly and now it doesnt come on at all. The car has been driving fine though, I dont notice any difference then before when i wasnt having light issues. Either way im gonna check the pressure today. Thanks for the advice.
minilogoguy18
Oct 23, 2009 12:49 PM
SofireGuy
Feb 16, 2009 10:08 AM
92civeg
Jan 15, 2006 04:49 PM
SixPAK
Aug 17, 2003 10:47 PM
