98 civic brake lock up.. Already searched
Old Jan 8, 2012 | 11:17 AM
PhrequenC's Avatar
Default 98 civic brake lock up.. Already searched
98 DX HATCH
Parts replaced..
Booster
Master
Prop valve from EX
All new lines
Integra rear brakes
EX calipers in front.
97 integra rear trailing arms
1 new rebuilt on front & 1 new rebuilt on rear.
Bled brakes numerous times
Basically, after driving around for maybe 20-30 minutes of driving the brakes lock up, only way to free them is to crack the rear bleeders.
Problem occurred with old booster & new, occurred with DX prop and ex prop.
Any help much appreciated.
Contact me directly if you want to
203-556-5439 text is easier
Old Jan 8, 2012 | 11:18 AM
TypeRfit's Avatar
RESIDENT
Default Re: 98 civic brake lock up.. Already searched
Check the adjustment on the shaft going from the brake to the booster. Probably just needs to be loosened up a little bit.
Old Jan 8, 2012 | 02:49 PM
PhrequenC's Avatar
Checked that out. Hasn't changed anything.
Old Jan 8, 2012 | 03:19 PM
canadaek's Avatar
rear flex hose's collapsing maybe ? try cracking the rear lines loose at the prop valve see if there is pressure there. if it was the master it should be one front and one rear as the brakes are run in an x pattern
Old Jan 8, 2012 | 03:48 PM
Former User's Avatar
Are all four wheels locking up?
Old Jan 8, 2012 | 04:10 PM
cpl rampage's Avatar
same thing happened to my friends accord when we did a AT to MT swap, we had tightened down the brake light switch down too far so that the brakes never fully released and slowly got tighter and tighter each time you pressed the peddle
Freshdot
10
Jul 23, 2010 06:01 PM
cautrell05
Mar 10, 2009 05:44 PM
civicex442
Apr 24, 2007 04:37 PM
93civicsedan
14
Aug 11, 2004 01:28 PM
lastlude2k1se
10
Jan 17, 2003 12:19 PM
