Overheating issue please help :)
Old Jan 6, 2012 | 05:45 PM
cadwiese's Avatar
Default Overheating issue please help :)
So i was driving my civic home today and i realized at a stop light that my car was getting above the half way point on the temp gauge. Thinking that it would maybe go down when i started driving i proceeded home....it got hotter I pulled over at a gas station and thought maybe the fan didnt turn on so i poped the hood and saw that it was on. I touched that radiator cap and it wasnt hot so i didnt the dumb thing and opened it and got fluid everywhere Im guessing that my thermostat has went bad but what do you think?
ty in advance
Old Jan 6, 2012 | 05:48 PM
Dc4LsTeG's Avatar
EK9
Default Re: Overheating issue please help :)
Did you feel your bottom hose?does your top hose look like its expanded
Old Jan 6, 2012 | 05:49 PM
cadwiese's Avatar
both hoses look good but the bottom seemed hotter then the top
Old Jan 6, 2012 | 05:52 PM
grumblemarc's Avatar
The Grumpiest
I think at the very least you should try and replace the thermostat.
Old Jan 6, 2012 | 05:54 PM
cadwiese's Avatar
ya and im going to replace the cap also....
Old Jan 6, 2012 | 05:56 PM
The Grumpiest
Curious. When was the last time the timing belt/water pump was replaced?
cadwiese's Avatar
12k ago when i rebuilt the engine
Old Jan 6, 2012 | 06:51 PM
94EG8's Avatar
Seagull Management
You're lucky, you can get some pretty nasty burns that way. If you have a blown headgasket especially that cap can be under a hell of a lot of pressure.
Try a new thermostat and cap and go from there (oem not aftermarket junk, I've had some many issues with aftermarket thermostats it's not even funny)
I would also do a compression test on it. Maybe do that first actually.
TheWizard14
Sep 7, 2015 01:34 PM
motegicivic
Jul 14, 2012 04:39 PM
Utilitarian
Sep 14, 2007 11:20 AM
silvsrt4
Oct 1, 2005 04:25 PM
Typiko512
Oct 1, 2002 07:31 AM
