hole in cam lobe !
Old Jan 5, 2012 | 11:37 PM
todahead's Avatar
Default hole in cam lobe !
it's the second time i check my vt since i bought the car
and i think it wasn't there in the first time
cams are stock b18c5 cams engine is compete stock
oil is ams oil and valve lash was too tight on the first time i check it but i fixed it to oe specs after that.
can this make any more damage since its on non vtec lobe ?
Old Jan 5, 2012 | 11:57 PM
b20vtech's Avatar
Default Re: hole in cam lobe !
possibly it can start to chip off bit by bit or start a crack line
You can possibly debur the edge of that chip to stop it from cracking or chipping again.
Old Jan 6, 2012 | 09:48 AM
admassa's Avatar
I would replace the cam ASAP, here's why. The cam lobes are all heat treated for durability. From what I can interpret, that deformity has damaged the heat treated surface (think of a shell on an egg hard as hell but once it cracks?) the under lying material cannot handle the forces placed upon it and now that is exposed. IMO this is going to continue to degrade and eventually cause some major damage. What does the follower (rocker) look like? I'd bet it's damaged too.
Old Jan 6, 2012 | 10:14 AM
todahead's Avatar
...no it looks perfect no marks etc
ctr/itr cams are really rare these days ...
it may take some months till i find a set
Old Jan 6, 2012 | 10:21 AM
admassa's Avatar
You may be lucky I sincerely hope so however for me personally the risk/reward of running the cam like this wold be too much. As far as the new cams go, you can find them but you're going to pay though the nose for them. Best of luck!
Old Jan 6, 2012 | 11:06 AM
95skunkedgsr's Avatar
... there is plently of aftermarket cams that are only a tad bigger then hype r cams
Old Jan 6, 2012 | 08:13 PM
todahead's Avatar
with good quality as oem ones ?
Old Jan 6, 2012 | 08:29 PM
f20b jones's Avatar
Run the cam man it will be fine . Ive seen alot worse then that run . I prefer my stuff to be perfect and i wouldnt sell anything like that but honestly its not going to hurt a damn thing . I bet the rocker doesnt even touch that part of the cam lobe . I doubt its from anything you done like other cams ive seen damaged . Thats probably just a bad casting flaw . I also dont beleive that will start tpo crack or it would have when it chipped off. Im sure nobody wants to get on the computer and say hey man run a cam that has chipped it will be fine but i tell you what run them then post up the results every month . I bet the cams out live the motor . Ill tell you what pull them out and sell them to me for 50 bucks im sure i can find plenty of people that would like to have them.
skill178
Feb 11, 2013 08:51 AM
EmminoDaGreat
Aug 26, 2012 11:02 AM
250r king
Mar 13, 2010 10:32 AM
toooslow
Apr 10, 2003 11:41 AM
TurBoTeG
Aug 15, 2002 10:33 AM
