Above 4500 rpm I notice a whining sound like a supercharger - ANY Help?
Old Jan 5, 2012 | 09:45 AM
97G_TechLX's Avatar
Icon7 Above 4500 rpm I notice a whining sound like a supercharger - ANY Help?
OK so its a Turbo b16a2 ek 4dr. Basically here's wuts happening when in drive above 4500 rpm i notice a whining like supercharger sound which is bothering the crap outta me. I havent noticed any power loss no cels on. Only thing is I cant remember if the sound was still their before i put the competition stage 4 clutch in or not?? Only things I can think of being too much/ too little tranny oil?, timing belt?, or alternator bearings? I highly doubt the motor is making the noise its been completley gone through!
Anyone ever had this happen?
Old Jan 5, 2012 | 09:46 AM
sfar785's Avatar
Default Re: Weird Sound??? ANY Help...
timing belt too tight??
Old Jan 5, 2012 | 03:52 PM
hmonguy918's Avatar
hmm... have u tried steping the clutch in to c if it still whines? try stepping in the clutch and listen to see if it still whines. if doesnt whine when the clutch pedal is step on then it could be the clutch is not setted in right or it can be the bearing that is on the tranny that needs changing. those are my only ideas..also is it more like a wistle or is it more like a scrapeing noise?
Old Jan 6, 2012 | 10:29 AM
sde780's Avatar
Does it do that when you hit boost? Check the turbo for shaftplay...
Old Jan 6, 2012 | 10:30 AM
grumblemarc's Avatar
The Grumpiest
Exactly WHERE is this sound coming from from what you can tell?
Old Jan 6, 2012 | 10:40 AM
sde780's Avatar
At 20psi my turbo made a supercharger noise...get home and the compressor nut came off, compressor hit the housing, and I went from 0 shaftplay to 1/2" at least. Moral of the story: don't overspin stage 1 T3 turbines
Old Jan 10, 2012 | 08:31 AM
97G_TechLX's Avatar
Icon6 Re: Weird Sound??? ANY Help...
K far as I can tell it sounds like its n the head kinda. listened with a stethoscope. Im only pushn 6-10 psi right now. I have new bearings, arp rod & head bolts, stock head. But it starts around 4200 an gets a lilouder up to 6200 rpms then completley runs smooth throuh the rest of 8500 Ima post a vid. But ima try a a different oil 1st
BTW oil pressure is not an issue!
Old Jan 10, 2012 | 08:35 AM
97G_TechLX's Avatar
An yeah it happens boostn an w/o boost. I can run it up slowly w/o gettn in boost an the sound is much more audible of course!
Old Jan 10, 2012 | 02:51 PM
canadaek's Avatar
Default Re: Above 4500 rpm I notice a whining sound like a supercharger - ANY Help?
pcv clogged ? take the drive belts off and try it see if it goes away.
Old Jan 10, 2012 | 04:58 PM
czum09's Avatar
Check the valve cover bolts and any other bolts around the head. Could be something really simple (or maybe not haha). Keep us posted. Videos are great!
aj345
Aug 28, 2013 01:44 PM
dth0ng69
May 11, 2013 09:42 PM
dtran002
Feb 1, 2013 06:02 AM
teddy_dc2
May 5, 2006 06:26 AM
kihun_cha
Dec 3, 2005 07:24 AM
