Transmission Swap.
Okay, bottom line. I have a D16Z6, need to replace the transmission with a Y8 that I bought today.. If someone can please give me a step by step on how to swap the Y8 onto the Z6.. ( I need to put the Z6 clutch, flywheel, ect. onto the Y8 transmission )
Please give me some help here..
http://www.c-speedr.com/howto/b18cclutch/clutch.php
this is for B series but almost same for d series
Basically remove the axles, unbolt the slave cylinder (do not disconnect the line! Just unbolt the slave cylinder and swing it out of the way and you wont have to bleed it.)unbolt the transmission and drop it out the bottom. Installation is the reverse of removal. Also, you will have to reuse the upper mount from the Z6. All of this is covered in the F.A.Q.s sticky-ed at the top of the page.
S40. It really makes no difference for simply installing the transmission, it's only once you open one up that being an S20 or S40 matters.
From the manual (PAGE 13-5) so I don't forget anything (not word for word):
1. Disconnect battery.
2. Drain transmission fluid.
3. Remove intake air tube, intake air duct and air cleaner housing.
4. Disconnect starter motor cables, transmission ground wire, and back-up light switch connector.
5. Remove wire harness clamps.
6. Disconnect VSS connector.
7. Remove clutch line bracket, clutch line clamp, and slave cylinder.
8. Remove driveshafts.
9. Remove exhaust pipe A (header/Y-pipe).
10. Remove shift rod and extension rod.
11. Remove engine stiffeners and clutch cover.
12. Install bolts in cylinder head and attach a chain hoist to the bolts, then lift the engine slightly to unload the engine and transmission mounts.
13. Remove splash shield.
14. Remove right front mount/bracket.
15. Place a jack under the transmission.
16. Remove the transmission mount bracket and mount.
17. Remove the three upper transmission mounting bolts and lower starter mounting bolt.
18. Remove rear mount bracket bolts and transmission mounting bolts.
19. Pull the transmission away from the engine until it clears the mainshaft, then lower it on the transmission jack.
* Take care not to bend the clutch line.
The Y8 transmission should be an S40-K4F iirc. I thought S20 were the 5th gen transmissions.
Nope, the clutch and flywheel remains bolted to the engine.
It depends on what you're trying to swap. The forks don't swap, sleeves don't swap (not without modifications anyway) gears will though, and synchros, IIRC mainshaft, countershaft and diffs are interchangeable.
I picked up an S20 DX tranny at a local scrap yard for $15 a couple of weeks ago, realized it had been opened before and someone had replaced all the bearings (score!) it's got a bad 1st/2nd sleeve though, which royally sucks, I've got about 6 for S40s but the only other S20 one I have is even worse.
That wont cause that issue as long as you swap the gears on both the input and countershafts together. I'm willing to bet you accidentally used one of the wrong gears when putting it together. I've done that before, couldn't understand why the case wouldn't drop that last half inch, finally went and started counting gear teeth, had mixed up some DX and Si gears. It's easy to do. If they were both EX/Si trannys I'd say what happened was the S20 came from an Si it's got a slightly lower 5th than the S40 EX. You probably got the two larger gears which spreads the shafts just slightly.
It almost closes. Less than an inch to go for sure.
Dream
14
Sep 9, 2003 10:03 PM
