Oil loss help???
I was at full line on Thursday, checked Sunday and down a quart already?!?!?!?!
My car is 98 civic lx chasis, with 95 zc block and 98 ex Vtec d16y8 head, with auto trans...
I have a skunk 2 intake manifold, cold air intake, headers with down pipe, then rest of exhaust pipe is stock lx pipe with muffler stock...
I did full tune up, (changed pcv also)... Did compression test on cylinders, readings were 225,223,215,230... Had head checked before mini me swap, vaccuum test were good on it, I set my timing to 18 degrees, spark plugs .044, using 10w30 oil...
One check engine light for secondary o2 not being hooked up(don't see that losing oil)
I notice that when Vtec pops alittle white cloud poofs out...
Anyone have any idea where my oils going?
I've replaced all oil leaks including main seals, entire block is clean
Well I can see I might have a head Gasket leak for the coolant going into the combustion cause of the white smoke but where's my oil going? Block cleaned, no leaks, no black smoke, not mixing with coolant, no power loss at all, car runs full power, compression test good, any idea guys?
Alot of you guys need to read dudes 1st post. I say your burning it up. Maybe your valve seals are JUST starting to go so under wot it's burning da oil and your 215 compression on that cylinder should be your leak area for the coolant.
