Oil loss help???
Oil loss help???
I was at full line on Thursday, checked Sunday and down a quart already?!?!?!?!
My car is 98 civic lx chasis, with 95 zc block and 98 ex Vtec d16y8 head, with auto trans...
I have a skunk 2 intake manifold, cold air intake, headers with down pipe, then rest of exhaust pipe is stock lx pipe with muffler stock...
I did full tune up, (changed pcv also)... Did compression test on cylinders, readings were 225,223,215,230... Had head checked before mini me swap, vaccuum test were good on it, I set my timing to 18 degrees, spark plugs .044, using 10w30 oil...
One check engine light for secondary o2 not being hooked up(don't see that losing oil)
I notice that when Vtec pops alittle white cloud poofs out...
Anyone have any idea where my oils going?
I've replaced all oil leaks including main seals, entire block is clean
Re: Oil loss help???
Def no visible leaks? check real good, dizzy, valve cover area, cam seal, vtec solenoid, then get under the car, check rear main seal etc.
If all that checks out it is prob rings.
Well I can see I might have a head Gasket leak for the coolant going into the combustion cause of the white smoke but where's my oil going? Block cleaned, no leaks, no black smoke, not mixing with coolant, no power loss at all, car runs full power, compression test good, any idea guys?
It's possible you're just burning the oil. But a white smoke sounds like a headgasket problem to me... Is there any oil dripping from under the car?
