92 civic front brakes locking up
Old Dec 29, 2011 | 06:10 PM
egvr4's Avatar
Default 92 civic front brakes locking up
I bought a civic with jdm type r 4 lug swap 4x114, same as 93 prelude lug pattern. I have replace the booster, the master cylinder, and calipers and brakes are still locking up. The brake pedal gets real hard, and the car will not move at all.
Old Dec 29, 2011 | 06:13 PM
slowturbocx's Avatar
Default Re: 92 civic front brakes locking up
The pin in the master cylinder/booster needs adjusted.
Old Dec 29, 2011 | 06:15 PM
TypeRfit's Avatar
RESIDENT
This man is correct. Basically its the push rod between the brake pedal and the booster. Loosen it up a little bit and problem should be solved
Old Dec 29, 2011 | 06:25 PM
egvr4's Avatar
Ok thanks I will try it tomorrow
Old Dec 30, 2011 | 12:08 AM
Mashimaro's Avatar
Are you sure the calipers are not seized as well?
Old Dec 30, 2011 | 10:59 PM
egvr4's Avatar
Still having a problem, found out all the brakes are locking up
Old Dec 30, 2011 | 11:00 PM
egvr4's Avatar
Adjusted the rod out but going to try to adjust it again
Old Dec 31, 2011 | 08:09 AM
Former User's Avatar
pedroa06
Sep 3, 2009 06:23 PM
daniel_yu
May 20, 2008 05:35 AM
rollie_jimenez ef9
10
Nov 4, 2007 02:15 PM
miataguy
Sep 19, 2003 10:54 AM
EricUSC
May 1, 2003 09:23 PM
