suspension setup
Old Dec 27, 2011 | 10:35 AM
jshaw23's Avatar
Default suspension setup
I was wondering what coilover setups people r running and what u recommend for my bb6. Thanks in advance.
Old Dec 27, 2011 | 11:59 AM
apexi_bb6's Avatar
Default Re: suspension setup
Koni yellows with ground control coilover kit, 350 lbs/inch front, 300 rear with neuspeed rear sway bar. Had that setup for about 4 years and love it. Having a bigger rear sway is much better than using high spring rates for reducing roll in turns. at least for my street car. Brian (mugen22) and clint (drnirvtec) helped me as far as choosing the setup for street use and occasional track days.
Put the ebay equivalent on my friends sh and it was pretty bad. Definitely recommend spending the extra $100 and buying the real deal.
Only problem ive had was one shock started to leak. Called koni and they sent me a new one, then refunded my money once I sent the old one back.
Old Dec 27, 2011 | 12:18 PM
jshaw23's Avatar
Thanks for the input, I've heard nothing but good things about the konig/gc setupe
Old Jan 2, 2012 | 07:15 AM
mugen22's Avatar
Hey, that is me! Still glad you are enjoying the effects of a stiffer rear swaybar!!
I had Koni Sports with an Eibach Pro-kit for about 10 years and loved the combination. The adjustment on the Koni's offers a far greater range than pretty much anything out there. Some may say their technology is antiquated but the simple reality is Koni works! I finally replaced mine with another set of Koni Sports but they are SPSS3 (race) valved for my spring rates (14k front, 12k rear ) and they are great. Still streetable, just barely, but I am more focused on track day driving and eventually racing than I am about street comfort.
If this is your DD, go with 450-500lbs springs front and 350-400lbs springs rear. Then get yourself a rear swaybar (Neuspeed or Progress) and you will be happy for a long time. I also recommend going with straight race springs versus Ground Control's "bell" springs. You will have to have a custom upper spring isolator fabricated, but it will give you the flexibility to run just about any rate 2.5" spring your dampers can handle. Get yourself zero rate helper springs as well. Ground Control will tell you that you won't need them, but in hard, sharp, bumpy corners, the rear springs may tip in. Do it right, do it once!
Finally, don't go much more than 1.5" down from stock. The upper control arm will bottom out unless you go much stiffer with the springs. Also, cut about 1/3 off of your OEM bump stops.
Hope that helps!
Brian.
Old Jan 3, 2012 | 07:24 AM
specbb6's Avatar
tein ss coilovers. ride and height adjustable, perfect if youre just the casual autoxer like me.
DopeCD5
Jun 11, 2016 11:25 AM
shanez
Suspension & Brakes
Nov 21, 2011 08:53 AM
Xathine
Suspension & Brakes
12
Oct 27, 2008 04:52 PM
EK4civichatch
Sep 24, 2004 02:06 PM
Nothing.Special
Jun 3, 2004 11:35 AM
