Late Old 70's Autometer in Civic 1992
Old Dec 24, 2011 | 10:02 AM
9tailsfox's Avatar
Icon2 Mechanical Autometer possible run in my civic?
Hello to everyone in Honda Tech, This is Paul from Malaysia wishing you all a Merry Christmas and Happy New Year 2012.
Well another new year is coming... still single
So question.... Possible a Mechanical Tachometer run in a modern 1992 Civic? Well is could be a silly question before year 2012. But man I love that old Autometer tachometer #5711 that I saw on Ebay. It is about 3 3/4 inches diameter with 11k dial in it. I just love it. I know there are newer electrical tachometer with 4 wires and is totally compatible with my Civic from Autometer. But I just love the one I loved. So I check online that old Mechanical tachometer need to be run only with the sender(#605). This old Obsolete Model #5711 comes with the sender part number 605 and the cable Twin Black = (looks like a lamp cord) with another red wire which i believe is for the ignition(key on power supply) Also drive tip which i also believe for placing in the distributor( GM motor?)
So Any possible way to run this tachometer without the sender? or just plug these 3 cable in my Civic? Any suggest? I an electrical idiot... not pay enough attention once in school
Old Dec 25, 2011 | 01:59 AM
9tailsfox's Avatar
Default Mechanical Autometer possible run in my civic?
bump to 2012
Old Dec 25, 2011 | 04:33 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Late Old 70's Autometer in Civic 1992
Pics of this monstrosity.
Old Dec 25, 2011 | 06:59 AM
9tailsfox's Avatar
Here are the pictures
Is Autometer size 3 3/4 inches Tachometer
Old Dec 25, 2011 | 07:24 AM
The Grumpiest
What wires are what on this thing?
Old Dec 25, 2011 | 07:26 AM
9tailsfox's Avatar
it looks like a lamp cord wire... Both in twin black
http://www.autometer.com/tech_faq_an...x?sid=6&qid=18
What Are These Colored Wires On My Tach For?
• Red = key on power supply
• Black = common chassis ground
• White = dash lighting power
• Yellow = used only on Internal Coil Magneto tachometers as the signal wire
• Green = tachometer signal for standard or electronic ignitions
• Twin Black = (looks like a lamp cord) is used on External Coil Magneto tachometers that use an inductive pick up (#5210)
• Gray = for tachometers that use a Hi/Lo shift light. When grounded, Lo shift light point is active. When ungrounded, Hi shift light point is active.
• Blue = used on Playback tachometers to start recording (see playback tachometer instructions)
Old Dec 25, 2011 | 07:29 AM
The Grumpiest
Looks pretty simple to me.
Yellow-not needed.
Twin Black - Not needed.
Gray - Not needed.
Blue-Probably not needed.
Old Dec 25, 2011 | 07:37 AM
9tailsfox's Avatar
The Tachometer manual
Old Dec 25, 2011 | 07:56 AM
The Grumpiest
If that sender is absolutely necessary for it to run and it has to plug into a distributor then I would say it's incompatible. Someone with more electrical experience might have an idea to make it work.
Old Dec 25, 2011 | 08:00 AM
9tailsfox's Avatar
I thought it would possible ignore the sender just figure that twin black cable plug to my civic electronic ignition terminal. It seems like a risk.... hmmm
Old Dec 25, 2011 | 08:07 AM
The Grumpiest
Do you have a "External Coil Magneto tachometer"?
Old Dec 25, 2011 | 08:12 AM
9tailsfox's Avatar
no... Why?
Old Dec 25, 2011 | 08:40 AM
The Grumpiest
That's what the sender hooks into. If the sender is necessary for this thing to work then you cannot use it.
Old Dec 25, 2011 | 08:45 AM
9tailsfox's Avatar
Aw.... Man Wish this thing can be work. Maybe I find my self another working one... Well thank you and happy holiday
BEN52
Dec 26, 2004 08:34 PM
BoOsTeD_eK
Oct 21, 2004 02:00 PM
dynamicauto
Aug 11, 2004 03:23 PM
95dxhatch
Apr 28, 2003 05:33 PM
Soled Out
Jan 21, 2003 05:09 PM
