89 Squeeky Speedometer Si
little by little my speedometer is getting squeeeky WTH? any suggestions would be helpfull i am thinking of spraying some WD40 what do you guys think? while driving i do feed a little vibration on top of the speedo cover.
WD40 is a truly terrible way to try and quiet any noise down. It isn't intended to provide lasting lubrication, so even if it does fix anything the issue will return in days.
i have the same issue in my 90 CRX Si
when it's cold out, more so.. but it squeeks a little as is spins right under the dash/gauges
remove dash, remove cable, clean/oil cable? put it all back together.
Mine did that too.pull it from the back of the speedo and the Trans.pull the cable out of its sleeve.use grease to coat the cable (lightly but a Lil extra won't hurt).reinstall..
89brokendownEF
May 15, 2014 05:03 PM
Krakkles
Oct 16, 2004 02:14 PM
