damn radiator hoses still
so i checked my cap its the right one i left it off till my car heated up to temp burped one bubble and that was it put it back on and contintued watching my upper hose over expanded again and got warm again but my lower hose was cold but was normal pressure. my car still doesnt overheat but i noticed my fans dont kick on ever..??...what could this be?? thermostat? bad fan motors?..my fuses all seem to be fine..need to fix it asap
where would it be blocked? in my hose? or in my motor?..or what and how would i flush or try n unblock the hoses and radiator and motor?
Have you replaced/checked anything past getting the air out of the system? Is your fan actually working? Replace that hose at the very least. New thermostats aren't that expensive either.
ive watched it long enough for the motor to be completely warmed up and the fans should have kicked on by then you would think but iv never seen them work yet i just bought thr car a few wweeks ago and iv periodically checked to see if they work but have never seen them kick on yet
well theres no reason it shouldnt right? its all wired fine and no fuses are blown how do i check and make sure there working correctly?
so i just put my old rad cap back on and the upper hose deff didnt build any pressure at all car staid at normal temp and fans never kicked on put new cap back on hose over expanded again and car stayed in normal temp fans still didnt kick on and the whole time my lower hose stayed cold ...what would cause this?....
Jump the fan connector, un plug it at the thermostat take a paper clip and put each end in each hole in the connector then turn the car to position 2 and see if the fan works.
It takes a lot of running to get the fan to kick on by itself.
yeah jump the fan as said earlier. if it starts then fan is ok
then if your lower hose stays cold even with old cap then ur thermostate is stuck close.
as for over expansion of upper hose, ur new cap is out of specs i.e. not opening & letting the water/coolent to reserve bottle
Here do what i did
1st run a water hose trough your heater core in the opposite way it circulates for about 3 minutes
2nd replace the thermostat with an OEM t-stat
3rd use distilled water in the system untill all coolant is gone and the debris too just keep pouring it in while you have the radiator plug loose i used 3 gallons
4th use 50/50 pre dilluted coolant
5th let the heat slider be all the way on warm but no fan on so it gets hot and the coolant circulates all the way trough the system
6th burp the system again took me about 1hr to do it on mine
put the radiator cap back on and top up you overflow tank see if it works
how are you going to build a K24 if u need to take a car to a shop to replace the T stat and a hose
Here do what i did
Here do what i did
Ek9_Cuhzz
12
Nov 3, 2010 02:35 PM
