H22A Turbo 6765H .81 A/R vs .68A/R hots side Witch is better
Hello as the title says I can't decide between the .81 A/R hot side or the .68A/R for my setup... I'm currently Running a Turbonetics 1.15 A/R divided hot side on an open manifold so im loosing out on that precious spool time as it is... I'm trying to pick up at least 1000k of spool witch one should I use without choking my top end power here is my dyno sheet as of now..
A lot would depend on the setup, what kind of power are you shooting for ?
Keep it small, as long as the exhaust wheel doesn't change, and it might help you with the amount or powerband you're looking for. But you're asking a lot for such low boost pressure on an enormously large turbocharger for only 2.2 litres.
Do you have a printout with boost? When do you have your vtec starting?
You would be better off with a 6262 for that power level and your goals of spooling sooner IMO.
my vtec is set to 4.5k yeah I agree with the 6262 being beter suited I pucked this turbo up for 850 bux brand new from a friend so i couldnt pass it up!
javi/eg6
Nov 12, 2011 09:53 AM
