d15b7 turbo using p28 and injector size?
Old Dec 19, 2011 | 12:36 PM
beginmyhonda's Avatar
Default questions answered PLEASE DELETE!
94 civic cx with a d15b7 turbo on 3 or 5psi wastegate soon
gonna run this til my built z6 is ready
i have a p28 ecu that was tuned for a stock z6 on 7psi
my question is can i use the p28 on the d15b7 and retune and disable vtec
or do i have to get my po6 chipped and tuned?
also will stock 240cc hold 3 or 5psi with B&M fuel pressure regulator?
ive read that it can and cannot
i do have precision 650cc saturated
thanks
Last edited by beginmyhonda; Dec 19, 2011 at 03:34 PM. Reason: answered my question
Old Dec 19, 2011 | 12:53 PM
grumblemarc's Avatar
The Grumpiest
Default Re: d15b7 turbo using p28 and injector size?
And out of all that no one has any idea WHAT turbo you're using.
Throwing PSI numbers around without knowing that is useless. Also you tune for the setup. Not the "PSI". It tells me you don't have a clue as to what you are doing.
If you turbo the car you need to upgrade the injectors and the fuel pump. No you cannot use the MAPs that are on the P28. Get a new basemap.
Do some more reading. You shouldn't even need to be asking such questions if you did the proper research.
Old Dec 19, 2011 | 02:36 PM
apexi_rsx's Avatar
just put the 650's in and tune to that. it could probably run the stock injectors on 3-5psi but it will be weak and ur gonna wanna turn the boost up. they will be running at 100% duty cycle pushing the injectors past 5 psi. its not good to max injectors out to 100% duty cycle
Old Dec 19, 2011 | 02:47 PM
owneyboy's Avatar
is your p28 chipped? i would just use that and put a new map onto that chip if so. maybe $10-25 dollars for base map. if not your p06 would have to be chipped and vtec converted a little more money involved that route. and a fuel pressure regulator is pretty useless with stock injectors and in fact i doubt you will need them to run the 650s (depending on brand).
and yeah the 240cc injectors are at 110% duty cycle at 43 of fuel pressure. 6 psi of boost on typical ebay 50 trim turbo
240cc good for around 200bhp.
650cc good for about 430-450bhp.
Old Dec 19, 2011 | 03:20 PM
PLEASE DELETE!
Old Dec 19, 2011 | 03:23 PM
EsotericImage's Avatar
Retired Moderator
answered in your other thread..
you only need to post the same question once.
https://honda-tech.com/forums/forced-induction-16/d15b7-turbo-using-p28-injector-size-3009356/
Old Dec 19, 2011 | 03:32 PM
PLEASE DELETE!
Old Dec 19, 2011 | 03:33 PM
PLEASE DELETE!
Old Dec 19, 2011 | 03:35 PM
Retired Moderator
wake me up when the turbo spools.
Originally Posted by beginmyhonda
let me rephrase it's pretty simple how one ht member couldnt understand lol
going to run d15b7 turbo
reuse chipped p28 with new basemap and disable vtec? or
have to chip my virgin p06 and tune?
Please dont call it a basemap. its not a basemap. once your tuned its now a custom map tailored to your set up
The Grumpiest
im not even talking about what turbo im using because there no point about it
No point? OMG. Funny how people never acknowledge that you give them info but only want to comment on the perceived attitude. Next time give all the info up front.
Old Dec 19, 2011 | 04:12 PM
PLEASE DELETE!
Old Dec 19, 2011 | 04:21 PM
Retired Moderator
u probably have 2-3 days before a mod will get to this thread..
beginmyhonda
Dec 19, 2011 03:21 PM
mxjosh
Sep 15, 2011 08:15 PM
lilshady6796
Nov 30, 2009 07:23 PM
chrispittman
Sep 4, 2007 10:46 PM
SOHC_MShue
Feb 27, 2004 06:40 AM
