Check engine light ON, vtec still works
Old Dec 18, 2011 | 11:20 PM
TurkeySlayer's Avatar
Icon2 Check engine light ON, vtec still works
I drive a 2000 Honda civic SI which I've had for 5 or so months, I was not experienced in driving a car with a manual transmission so it tool me some time to get used to the way it all works. I've been doing a lot of reading on the way that vtec works and all that and I found out that if your check engine light is on vtec will not engage. Well my check engine light is on but I can still shift all the way up at 7000 something that I found out from reading a post in another thread that I would not be able to do if vtec wasnt engaging. Has anyone else ever seen this happen?
Old Dec 19, 2011 | 01:33 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Check engine light ON, vtec still works
pull the check engine light using the link above or use a scanner and post code
Old Dec 19, 2011 | 05:26 AM
kyden's Avatar
it depends on the code.
Old Dec 19, 2011 | 10:24 AM
cvcrcr99's Avatar
Depending on the code. My vtec still engages although I have a VSS sensor issue at the moment.
Old Dec 19, 2011 | 10:28 AM
undrgrndkng's Avatar
Check this thread out:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Figure out the code and post it up.
Old Dec 19, 2011 | 10:37 AM
DCRB's Avatar
your vtec probly isn't engaging, rev limit with vtec on a b16a is mid 8k rpms, not 7. you shouldn't be taking your car that high if your cel is on any ways that's asking for trouble.
springfieldcivic
15
Jun 24, 2005 02:26 PM
brian2903
May 2, 2004 12:10 PM
snoop_005
Jan 3, 2004 11:45 PM
inzaneN1
Dec 3, 2003 01:34 AM
boosted spoon
Jul 23, 2002 12:08 PM
