Changing my CAT
Old Oct 7, 2002 | 09:29 PM
Toptul_Honda's Avatar
New User
Default Changing my CAT
how hard is it to do? Do i have to change any gaskets? I see two bolts with springs. If i take em off, will it be a bitch to put back on?
need help. Any digrams and lits of tools would be greatly appreciated
Old Oct 7, 2002 | 09:36 PM
Aphrodavid's Avatar
Default Re: Changing my CAT (TreCRX-DX-SI-CX)
not hard, no gaskets, all youll need is two wrenches to take off the spring bolts, no
[Modified by Fast 1point5, 10:37 PM 10/7/2002]
Old Oct 8, 2002 | 05:57 AM
New User
Default Re: Changing my CAT (Fast 1point5)
but i still have to compress the srping back right?
Old Oct 8, 2002 | 05:59 AM
EP3_05's Avatar
The spring is not hard to compress. You can do it by hand or use a c clamp. It is very easy.
Old Oct 8, 2002 | 07:00 AM
Rob!'s Avatar
Default Re: Changing my CAT (91civic)
very easy to do...i would be more worried of there is rustcuz thats usually more of a problem then the spring...the spring just compress with your hard and put the bolt on the other and then just tighten with the wrenches...very easy project\
Rob
Old Oct 8, 2002 | 04:37 PM
New User
Default Re: Changing my CAT (RaceFacer)
if i just ran my car how long should i wait till its cool to work with? i dont want to burn myself
Old Oct 8, 2002 | 05:56 PM
bfrank81's Avatar
It will probably take an hour for your car to cool down enough. those pipes get VERY hot and they will burn you in a sec. If the bolts are rusted spray them with WD-40 and let them soak for a little while.
Old Oct 8, 2002 | 07:49 PM
New User
Default Re: Changing my CAT (bfrank81)
sweet.. ill tackle it on friday and let u guys know if anythings wrong
Old Oct 8, 2002 | 09:05 PM
shortyz's Avatar
hate those ! arg.
Old Oct 9, 2002 | 09:28 AM
incubus's Avatar
i would be more worried of there is rust cuz thats usually more of a problem then the spring...
true dat, the last cat i replaced we had to torch the bolts off.
Old Oct 9, 2002 | 01:29 PM
SirYoda's Avatar
Default Re: Changing my CAT (incubus)
Ahh! Milwalkee "Sawzall" does wonders for removing garbage exhaust/bolts ect.
Old Oct 9, 2002 | 06:57 PM
New User
Default Re: Changing my CAT (SirYoda)
my emissions are horrible that why im changing.. ifi get a high flow cat do u think i can still pass aircare?
[Modified by TreCRX-DX-SI-CX, 7:57 PM 10/9/2002]
Old Oct 9, 2002 | 07:11 PM
NikoZai's Avatar
since we're on the subject and i'll be doing the whole system soon, where can you get replacement springs?
Old Oct 9, 2002 | 07:14 PM
MrTodd's Avatar
Yup - the highflow cats (catco at least) convert the hydrocarbons to Co2 just as efficiently as the stock cats...
Old Oct 9, 2002 | 08:09 PM
New User
Default Re: Changing my CAT (MrTodd)
would you say getting a high flow cat is worth it?
Old Oct 9, 2002 | 08:46 PM
B16pwrHB's Avatar
I have a sugestion for you instead of a high flow cat just get a reg. cat pass deq then bore your old one out and put it back on... More Flow
I like flow
Old Oct 9, 2002 | 08:52 PM
New User
Default Re: Changing my CAT (B16pwrHB)
what can i use to bore it out? i have 2 used ones that i got for free.
Old Oct 9, 2002 | 09:54 PM
New User
also, is there a way to clean the cat before i put it in?
Old Oct 10, 2002 | 07:42 AM
d357r0y's Avatar
i used an 18 inch long masonary bit.. ten times faster than beating it out with a length of pipe.
Old Oct 10, 2002 | 08:16 PM
New User
Default Re: Changing my CAT (d357r0y)
whats a masonry bit?
Old Oct 10, 2002 | 08:25 PM
matt j's Avatar
i need to change mine also except my back bolts are welded on. damn exhaust guys
Old Oct 10, 2002 | 10:33 PM
New User
Default Re: Changing my CAT (hybridturbo89)
i changed mine.. it wasnt too hard.. just needed a hand holding it up! thanks guys!
i have one where the bolts are welded... if one side can unscrew off then thats fine!
Old Oct 11, 2002 | 07:44 AM
matt j's Avatar
both sides of mine are welded
Old Oct 11, 2002 | 08:03 AM
New User
****. thats gay
Old Oct 15, 2002 | 06:24 PM
from_zer0's Avatar
Default Re: Changing my CAT (ZZZZZZZ)
Huh?!? No gaskets?!?
Mine had TWO gaskets...front & rear...91 civ w/b16...
What's the deal here?!? Do i not need those? Anybody know?
huge230
Aug 23, 2007 12:11 PM
BlackCRX
Jan 19, 2005 12:06 PM
oemDC2
Jan 1, 2004 08:24 PM
TAG
19
Jul 6, 2003 08:19 PM
crewjones
Sep 3, 2001 11:29 AM
