front spring bolts.....
Old Sep 2, 2001 | 06:00 PM
crewjones's Avatar
Default front spring bolts.....
how do you take off the front springs, I just got some eibach and can't take off the front springs, maby the bolt is frozen? NEED HELP!!!!!!!!
Old Sep 2, 2001 | 10:40 PM
S13Koop's Avatar
Default Re: front spring bolts..... (crewjones)
Lets ASSUME this is the front, which nut would it be? side or middle?
Old Sep 3, 2001 | 12:52 AM
CrAZyRaCeR's Avatar
New User
Default Re: front spring bolts..... (winglessR)
Two words and it'll solve your problem, "BREAKER BAR"!!!!!!
Old Sep 3, 2001 | 07:44 AM
crewjones's Avatar
Default Re: front spring bolts..... (CrAZyRaCeR)
last time I used a breaker bar I broke the head of the bolt off. which bolts do I have to take off for the front springs?
Old Sep 3, 2001 | 11:29 AM
Etylorcen's Avatar
After you compress the spring put an allen wrench in the top and hold it or have a friend hold it. Then use a wrench and pull hard as hell. What I did was i put in the allen wrench and stepped on it on the ground. Then took a boxed wrench and hit it with a hammer till it losened up and took it off. Pretty easy, just need some elbow greese. If you notice if you don't use an allen wrench the top of hte shock spins w/ the nut.
[Modified by Etylorcen, 8:30 PM 9/3/2001]
huge230
Aug 23, 2007 12:11 PM
microsoft_sux
Mar 28, 2005 02:58 AM
grngsr01
Jun 17, 2004 06:35 PM
Cryptopsy
Mar 27, 2003 10:16 AM
89 CRX SI
17
Jul 15, 2002 10:21 AM
