id2000
Old Dec 13, 2011 | 06:17 PM
dropped93ex's Avatar
Default id2000
Just received my Id2000's from tony@ t1 and was wondering how to wire these up cuz my id1000's I had plug and play adapters and I came to find out today that the clip is different so my plug and play pieces won't be able to be used ... Needless to say hugeee bummer ... Car is a 93 civic ex with gsr .. need to know how to wire the clips ... thanks guys
Old Dec 14, 2011 | 06:58 AM
silverwrench's Avatar
Default Re: id2000
why not ask the guy you bought them from?
Old Dec 14, 2011 | 07:12 AM
xenocron's Avatar
Default Re: id2000
Cut off the old plugs and crimp and wire on the new ones that came with it!
He also sells adapters that allow you to make it plug and play. But crimping on its own connector is a much more solid way to do the install (less chance of another clips coming loose or losing contact).
Old Dec 14, 2011 | 07:14 AM
Muckman's Avatar
Moderator in Chief
Default Re: id2000
Using clips is 100x better than pigtails or adapters. You need a crimping tool first, you cut off the old connector, strip about 1/8" of shielding off the end of each wire, place the bare wire in the end of the pin, crimp the pin over the wire. Depending on the connector style you either push the pin into the back of the connector or you have to run the wire through the connector before you crimp then pull it back into the connector.
Old Dec 14, 2011 | 07:32 AM
Default Re: id2000
Silverwrench ur a douchebag... All others thanks for the responses
Old Dec 14, 2011 | 09:08 AM
92frostwhtdb2's Avatar
Default Re: id2000
I like to solder and heat shrink
Old Dec 14, 2011 | 09:10 AM
grumblemarc's Avatar
The Grumpiest
Default Re: id2000
Sounds like a legit question to me.
Old Dec 14, 2011 | 09:29 AM
turbohatch96y7's Avatar
Default Re: id2000
Yeah I would solder and heat shrink the connections. Crimping connectors look like *** in ur engine bay and will devolp corrosion inside the connector it self unless you buy the connectors with heat shrink around them but still looks like ***....
Old Dec 14, 2011 | 01:25 PM
digital sol's Avatar
Default Re: id2000
Old Dec 14, 2011 | 01:40 PM
Muckman's Avatar
Moderator in Chief
Default Re: id2000
Turbohatch96y7 youre thinking of butt connectors.
We are talking about about connector pins.
This
http://www.thunderboltrc.com/ashlok/...pTutorial.html
Old Dec 14, 2011 | 02:52 PM
Default Re: id2000
Ive still seen both devolp corrosion in the wire. And if they get crimped wrong it can break the wire inside the connector causing a loose connection. This is for an injector I wouldnt risk a bad connection running lean and BOOM!
Old Nov 4, 2012 | 10:07 PM
jose_gt_x's Avatar
Default Re: id2000
were can i get pins like that Muckman??
Old Nov 5, 2012 | 02:27 AM
IN VTEC's Avatar
Default Re: id2000
Go back to T1's site and order the adapters for the ID2k's.
Old Nov 5, 2012 | 06:59 AM
Muckman's Avatar
Moderator in Chief
Default Re: id2000
I got my clips and pins right from T1.
tglcivic
Honda Civic (2006 - 2015)
Mar 30, 2019 06:53 AM
williamcollins
Jul 8, 2017 01:24 PM
jdmsir4dr
Apr 25, 2013 08:33 PM
Nicaraguense13
Jul 28, 2008 12:21 PM
daklown
Jun 9, 2004 10:12 PM
