HOW to WIRE a 8 wire to a 9 wire Plug
I bought a LS dizzy that has a 8 wire plug as so.....
To this 9 wire Ek plug
Need help setting up the wires anyone kno how to do it??
Basically I kno i have to cut the 8 plug and connect that 9 plug but which one to connect and what do i do with the missing wire
Modified by Nicaraguense13 at 10:09 PM 7/27/2008
Re: (Nicaraguense13)
what exactly are you trying to do? you might wanna include year/model info on future questions. what year is the dizzy and what year is the harness? because 99-00 dizzys are missing a wire that goes to the icm....if yer putting a 99-00 dizzy on a pre-99 car you will need to add that wire the dizzy...open it up and look inside there will be a pin on the icm with no wire on it...thats where the extra comes from. if yer trying to put a pre-99 dizzy on a 99-00 just leave the extra wire out...cut it off an tape it up good so it doesnt touch anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakasis »</TD></TR><TR><TD CLASS="quote">....will need to add that wire the dizzy...open it up and look inside there will be a pin on the icm with no wire on it...thats where the extra comes from....</TD></TR></TABLE>
im assuming you have both dizzys....follow all the wires on the 98 dizzy and see where they go in the plug...then follow all the wires in the 99-00 dizzy and put em all in the same places as the 98 (including the extra wire you have to add)
Re: (freakasis)
FOUND IT!!!! thanks its the dark BLUE WIRE on the left side ... where the wires run to the coil.... the plug closest to the coil is the one missing!!!
THANKS !!!!!
THANKS !!!!!
