97' Honda Civic not blowing any air.
Today i went to turn on my heat and my Civic would not pruduce and air at all, also my Cigarette lighter will not work or my ashtray light they simultaneously went out at the same time for no apparent reason.
Checked under dash fuses.
Anything i'm missing?
Thank's in advance.
Thank's in advance.
Wow third post in a day........if you scrolled down you would saw the same threads.
See if your thermostat is opening.
If that checks out, make sure your control on the heater is opening the control valve, if not you can open it by hand in the engine compartment.
Yes, i saw all those threads my problem is not related to any of them.
If you scroll down and read there threads they are haveing different issue's. My Civic will not blow ANY air.
I don't think they use the same fuse. Remove your center console and check the wiring harness behind the light/lighter, see if there is any bare wires touching each other or the chassis to where it's grounding out
trendkill
Jan 30, 2013 10:25 AM
BrenaNickels
Aug 24, 2008 06:10 PM
shamoo
Sep 8, 2005 03:26 PM
