97' Honda Civic not blowing any air.
Today i went to turn on my heat and my Civic would not pruduce and air at all, also my Cigarette lighter will not work or my ashtray light they simultaneously went out at the same time for no apparent reason.
Checked under dash fuses.
Anything i'm missing?
Thank's in advance.
Thank's in advance.
Re: 97' Honda Civic not blowing any air.
Wow third post in a day........if you scrolled down you would saw the same threads.
See if your thermostat is opening.
If that checks out, make sure your control on the heater is opening the control valve, if not you can open it by hand in the engine compartment.
if fuses are good check the blower motor wire it up directly to the battery see if it turns on could be a bad switch in the climate control
I don't think they use the same fuse. Remove your center console and check the wiring harness behind the light/lighter, see if there is any bare wires touching each other or the chassis to where it's grounding out
trendkill
01-30-2013 10:25 AM
BrenaNickels
08-24-2008 06:10 PM
shamoo
09-08-2005 03:26 PM
