240 sx ka built turbo wtt wts
I have a 1989 Nissan 240 sx clean title both tags up to date I'm looking for clean trades or straight cash or cash and trade open to all offers please no junk be serious car runs good would need a better tune to be at its full potential car is super reliable I have driven it 200 miles away and back without a problem and got good gas mileage asking $7k obo
ENGINE
-KA24E SOHC 12V Totally Race Rebuilt at 183115 Miles -KA24E Head Milled and Totally Rebuilt With New Seals and 3 Angle Valve Job -KA24E Block Decked Fully Redone and Bored .020 Over (89.5 mm) With All New Seals and Water Jackets -Eagle H Beam Forged Connecting Rods with ARP Hardware -Arias Dished 8.8:1 CR Forged Pistons .020 Over (89.5 mm) -Clevite 77 Standard Size Main and Rod Bearings -KA24E OEM Forged Crankshaft Fully Repolished -ARP Custom Ordered 10mm Head Studs -ARP Main Studs -Cometic KA24DE Head Gasket Modified to Fit KA24E 90mm Bore .045 Thickness -Fel-Pro Head and Block (Conversion) Gasket Sets -Nismo 62 Degree C/169 Degree F Thermostat -Duralast Water Pump -Melling 280zx Turbo High Flow Oil Pump -Cloyes Complete Timing Kit -KA24E Motor Mounts Filled With 3M Windo-Weld -Custom Made Oil Catch Can -EGR System Removal -PCV System Removal -Emissions Removed (Except Idle Control) -Added 2 Extra 4 Gauge Ground Wires -JGS KA24E SOHC Turbo Manifold -JGS Turbo Elbow/Upper Downpipe -JGS Wastegate Dump Tube -JGS T3 Stud Kit
-Garrett GT3076R Dual Ball Bearing Turbo, Oil and Water Cooled (700382-5012) Turbine
-Wheel: 60mm w/ 84 trim -Housing: .63 ar Compressor -Wheel: 76.2mm w/ 56 trim -Housing: .60 ar
-ATP Turbo GT30R T3 Inlet/5 Bolt T3 Outlet .63 A/R (60mm) Turbine Housing -Stainless T3 Turbo Inlet Gasket -Stainless T3 Turbo 5 Bolt Outlet Gasket -Tial Polished 38mm External Wastegate with 1 bar (14.5 psi) spring -NXS Manual Boost Controller -Megan Racing SR20DET 3" Downpipe -Magnaflow 3" High Flow exhaust and 3 inch apex n1 muffler sounds good Braided Oil Feed Line Teed Off Oil Pressure Sensor -Steel Weld on -10AN Oil Return Bung with -10AN Oil Return Fittings -Stainless Steel Braided PTFE Hose with High Pressure Hose Sealing Joint Fittings -CXRacing 2" Core Radiator with 2 12" 1550CFM Push/Pull Electric Cooling Fans -Gladman Performance Radiator Diversion Cooling Panel -CXRacing 31x12x3 Front Mount Intercooler -Greddy Type RS Style BOV and 2.5" Pipe -2.5" Hot Side and 2.75" Cold Side Intercooler Piping (2" Turbo Outlet to 2.5") -Nissan 300ZX Turbo (Z32) N62 Mass Air Flow Sensor (4" Turbo Inlet to 2.75") -K+N Cone Style Air Filter -4 Ply Minimum Silicone Couplers -T-Bolt Clamps on All Piping -Retrofitted A/C with R-134A Refrigerant -Replaced A/C Compressor -Replaced A/C Low Side Pressure Line Hose with Custom Assembly for Turbo Clearance -Replaced A/C Condenser Fan -Replaced A/C Condenser Fan Temperature Sensor Switch -Replaced A/C Expansion Valve -Replaced A/C Accumulator/Drier -Replaced Coolant Temperature Sensor -Replaced Coolant Temperature Gauge Sensor -Replaced Oxygen Sensor -Replaced Fuel Pump Hoses -Replaced Fuel Pressure Hoses -Replaced Brake Booster Hose -Cleaned IACV/AAC System on Intake Plenum -Megan Racing Brake Master Cylinder Heat Shield
TRANSMISSION
-KA24DE 5 Speed Manual from 93 S13 -RPS Max Street 6 Puck Clutch Disc, RPS/Exedy Hybrid Reinforced Custom Pressure Plate, Throwout Bearing, and Pilot Bearing (450 WHP Capable) -Fidanza 11LB Lightweight Racing Flywheel -Nismo Stainless Steel Braided Clutch Line with Clutch Loop Block Removal -J30 VLSD Differential with J30 5 Bolt Axles -Megan Short Throw Shifter Version 2 -Greddy Chrome Counterweighted Shift **** -Replaced Clutch Slave Cylinder -Replaced Clutch Master Cylinder -Replaced Lower Rubber Shift Boot -Custom Leather Shift Boot
TUNING
-U12 ECU Chipped, Socketed, and Tuned with Tunerpro RT -Moates Ostrich 2.0 Rom Emulator With Real Time Map Tracing -Walbro 255LPH High Pressure Fuel Pump -550cc Mazda RX-7 High Impedence Fuel Injectors -Custom Easy Connect Fuel Injector Clips -N62 (Z32) Mass Air Flow Sensor and Pigtail Soldered into Factory Harness -300ZX Twin Turbo Fuel Filter -NGK BKR7E-11 Spark Plugs Gapped at .28 -Ignition Components (Wires, Cap, Oxygen Sensor, and Rotor) Replaced With Stock Spec Parts -Spark Plug Boot Protectors/Heat Shields -Zeitronix ZT-2 Wideband O2 Sensor Controller and Datalogger Kit -ECUTalk USB Consult Cable and Software -GQ-4X True USB EPROM Programmer -ATMEL AT29C256 Computer Chips for ROM/ECU tunes
SUSPENSION
-Nismo Power Brace -Stance GR+ Pro Full Coilover Suspension Spring Rates: 8k Front, 6k Rear 16 Way Adjustable Dampers Adjustable Front Camber Plates Rear Helper Springs -Energy Suspension Polyurethane Front Ball Joint Boots -Energy Suspension Polyurethane Tie Rod Boots -Energy Suspension Polyurethane Front and Rear Sway Bar Endlinks -Energy Suspension Polyurethane Sway Bar Frame Bushing Set (24mm-Front) -Energy Suspension Polyurethane Sway Bar Frame Bushing Set (15mm-Rear) -Energy Suspension Polyurethane ... Rear Differential Carrier Bushing Set (J30 Diff) -Energy Suspension Polyurethane Rear Subframe Insert Set -Energy Suspension Polyurethane Steering Rack Bushings -Wicked Tuning Adjustable Front Tension Rods -Front and Rear Adjustable Aluminum Strut Tower Braces
INTERIOR
-Audiopage Alarm and Starter Kill with Intrusion Detection and Keyless Entry -Autometer Ultra Lite Vacuum/Boost Gauge -Autometer Ultra Lite Coolant Temperature Gauge -Single Din Triple Gauge Pod (One Spot Currently Covered) -Ever Start 25-3S Battery (540 Cranking Amps/450 Cold Cranking Amps) -Battery Relocated to the Trunk with 2 Gauge Power Wire -Marine Battery Box -Pioneer CD Player/Stereo -Pioneer Front and Rear Speakers -S14 Manual Front Seat Belts -S13 Grey Rear Seat Belts -S13 Grey Trunk Parts Including Cargo Cover -S13 Grey Door Panels -S13 Grey Interior Panels -S13 Grey Center Console -Replaced Brake Light Switch -Reinforced Brake Pedal Mounting Points and Installed New Switch Activation Parts -Replaced Hatch Shocks
EXTERIOR
-OEM Silver Paint with Custom Black Headlight Doors, Hood, Roof, and Trunk -Removed Black Molding and Pin Striping Around Car -Custom Zenki Bumper Cover Grill Openings for Intercooler and Radiator Cooling Efficiency -Zenki (Pignose) Front Lip -Zenki JDM Side Skirts -Zenki JDM Rear Lip -JDM 180sx Front Bumper Turn Signal Lights (Amber/Clear) -Gladman Performance Sleepy-Eye H4 Angel Eye Projector Retrofit Kit, Custom Painted Black a Little. . .. -Xentec 35W 6000k Bi-Xenon HID Retrofit Kit -Red/Clear Hatchback Tail Lights -Clear Front Side Marker Lights -6000k LED Side Marker and Bumper Lights (in the clear parts) -Red LED Rear Blinker Lights (for the clear parts) -17x8+35/17x9+40 Rays Engineering Volk Racing CV Pro Forged One Piece Aluminum Wheels (4x114.3, 5x114.3) Painted Matte Black -New Rays Engineering/Volk Racing Decals on Wheels -Nitto Neo-Gen Tires 215/45-17 BF Goodrich G-Force Sport Tires 255/40-17 (Rear)
Text me only with offers please no junk 214 982 8745 jay
I am open to trades please read add before any questions looking for
ENGINE
TRANSMISSION
TUNING
SUSPENSION
INTERIOR
EXTERIOR
It's around 350 wheel it needs a dyno tune to be perfect if I still have it in the beggining of the year ill
Have dynosaur performance tune it just haven't had time with the holidays
chadalac1712
11
Sep 25, 2007 07:49 PM
