31x12x3 or 28x8x4 intercooler for 600hp?
Old Dec 5, 2011 | 05:07 PM
0487erasmo's Avatar
Default 31x12x3 or 28x8x4 intercooler for 600hp?
Hi guys, i need your help! I undecided for the intercooler for my turbo Civic. What is the best for 600hp, 31x12x3 2.5 in/out or 28x8x4 3" in/out?
Old Dec 5, 2011 | 05:19 PM
TheShodan's Avatar
Moderator
Default Re: 31x12x3 or 28x8x4 intercooler for 600hp?
what make up is each intercooler? Bar & plate (Garrett, Precision, Spearco, Mishimoto [lower grade]) or tube and fin? (Godspeed, CX Racing, Greddy, or E-bay)
Size alone can't answer this question without knowing more.. Got a picture or two as to what you're considering?
Old Dec 6, 2011 | 04:25 AM
0487erasmo's Avatar
Thanks Shodan, in a moment I upload the pictures to see what you think. Both intercooler are from ebay, not much money for an excellent quality!
Old Dec 6, 2011 | 04:43 AM
0487erasmo's Avatar
28x9x4
31x12x3
What I mean is as more efficient intercooler, wider or higher? is better than 4 wide but more softly or one of 3 wide but higher? which one is more efficient?
Old Dec 6, 2011 | 04:52 AM
doug118's Avatar
4" wide for sure. As long as they are the same type
Old Dec 6, 2011 | 06:40 AM
TheShodan's Avatar
Moderator
Not if its killing his flow to the radiator it isn't, even if it allows for a over a 1psi pressure drop. If he has additional cooling options with his fans to compensate for the lack of airflow to the radiator, and uses a 4" Tube & delta fin design like he has, then he may be fine, but otherwise, he may experience cooling problems.. And that's not very efficient, is it?
For a tube/fin like that, I'd go taller before I'd go thicker.
Old Dec 6, 2011 | 07:13 AM
m3tech95's Avatar
go with the 31x12x3 i have one from godspeed... it looks identical to mine....the one i have is a bar and plate rated for 600hp...
Old Dec 6, 2011 | 07:26 AM
doug118's Avatar
I'd really hope he'd have efficient cooling if he plans to run 600hp
Old Dec 6, 2011 | 07:29 AM
TheShodan's Avatar
Moderator
It may be initially... but not if you block airflow to the important places.
Old Dec 6, 2011 | 06:41 PM
mmcd's Avatar
i have a 31x12x3 bar and plate. i made 532hp on it. by that time my air temps were getting high. im also on 2 1/2" ic pipe. im going with the pricision 650 or 750 not sure and upgrading to 3" ic pipe.. so if i were you i would aleast go to something 4" wide, and also 3" pipe.
Old Dec 6, 2011 | 07:40 PM
LocoJoe's Avatar
Doesnt specifically need to be bigger in size but the core be efficient. I had a Precision 600 and didnt hold even 500. Got a Vibrant 31 x 12 x3.5 and it held 600whp and didnt get hot on the cold side. That FMIC in the pic is EMUSA = garbage = Godspeed. Need to think of efficiency instead of size.
Old Dec 6, 2011 | 07:59 PM
TheShodan's Avatar
Moderator
Exactly, that's why I listed the better ones first. I know not everyone is made of money and a $100 or slightly more may hurt, but for a lot of people, they only want to pay ONCE for an intercooler, so its well worth it. If you can't afford it, that's alright, if staying lower boost pressures (relatively) but don't expect the same result when you push the car to higher boost pressures
REAL Garrett Cores
Spearco
Bullsh!t Cores -Fins aren't properly louvered. Not bad, but will hurt power when pushing it.
Godspeed
EMUSA -Copied the Apex'i "Delta" Fin design.. and did poorly in doing so.
Old Dec 7, 2011 | 04:20 AM
0487erasmo's Avatar
guys, thank you very much everyone for your opinions. Think you're right, I'll wait a bit more to have the money and buy a really efficient intercooler. Maybe a Precision or a garret core and make it here! But if I buy the garret core, which would be the ideal measure for an intercooler for 600hp?
Thanks to all
Old Dec 7, 2011 | 04:46 AM
hb_guy's Avatar
[QUOTE=TheShodan;46476723]Exactly, that's why I listed the better ones first. I know not everyone is made of money and a $100 or slightly more may hurt, but for a lot of people, they only want to pay ONCE for an intercooler, so its well worth it. If you can't afford it, that's alright, if staying lower boost pressures (relatively) but don't expect the same result when you push the car to higher boost pressures
REAL Garrett Cores
whats the bung for on the side for??
Old Dec 7, 2011 | 05:03 AM
kyden's Avatar
that just looks like a mounting boss.
Schurke
May 2, 2006 07:56 AM
Honda-Pilot
Apr 21, 2005 08:41 PM
RICE POLICE SIP
Feb 28, 2004 05:25 PM
johnqt3
Aug 8, 2003 03:53 PM
