how do u wire up vtec on a obd1 with a deleted pressure switch????
Old Dec 5, 2011 | 03:48 PM
TruVa's Avatar
Default how do u wire up vtec on a obd1 with a deleted pressure switch????
I have a 95 ls with a b20 vtec , I looked up several threads but can't
Seem to figure it out. Plz help
Old Dec 5, 2011 | 04:10 PM
DirtyDA9's Avatar
Default Re: how do u wire up vtec on a obd1 with a deleted pressure switch????
It's not a deleted pressure switch, it's just a jdm VTEC solenoid. Get a JDM ECU, they don't look for a signal from the pressure switch.
Old Dec 5, 2011 | 04:13 PM
DirtyDA9's Avatar
Or buy a "turboedit" chip, I'm pretty sure they sell them for OBD1, but it's called "1-wire VTEC". How it works- You hook up 1 wire from your AC relay to the VTEC solenoid, and the turboedit chip allows you to set the exact RPM in which you want the AC relay to engage the VTEC solenoid. Assuming you have gotten rid of your AC.
Old Dec 5, 2011 | 05:18 PM
B20ztek's Avatar
hope this helps
Old Dec 5, 2011 | 05:33 PM
HondaPartsHero's Avatar
Technical Hero
Also search for VTEC pressure switch bypass.
Freya Franco
Engine Management and Tuning
Dec 13, 2017 10:49 PM
Outkast95LS
Jun 3, 2007 07:58 PM
iNERtIA
Apr 3, 2006 09:42 PM
The Mole
Dec 17, 2002 12:52 PM
