89 crx engine harness
Yes, your engine harness will work and although the PM6 will start and run the B18 as long as it has an OBD0 ignition, you should get it chipped and tuned on Turboedit as there is quite a bit of difference in the fuel and timing maps. The best solution is to convert the CRX to OBD1 using a 92-95 ignition, a OBD0 to OBD1 ECU conversion harness, an OBD0 to OBD1 ignition conversion harness (if you don't know how to re-pin the connectors), and a chipped P28 ECU. It's also possible some of the sensors will need connector swaps depending on the year of the B18.
Last edited by It Wasn't Me; Dec 4, 2011 at 12:52 PM. Reason: Unauthorized solicitation
komet 163
Oct 18, 2015 04:43 PM
jarhead90crx
12
Aug 5, 2011 07:06 AM
