car cuts out in boost
hey guys my car is cutting out in boost and i cant figure it out. ive changed plugs and wires. new dizzy. car is getting fuel. it cuts out at anything over 10 psi mostly. my set up is garret 57 trim. tiel bov and waste gate. dsm 450s and a aeromotive fpr any help will help lol.
yes maybe map because stock cannot handel over 10.68 psi i beleive
edit: and u said it cuts out after 10 psi so give us more info on ur setup
its tuned on chrome and its stock map but this is the first time ive had a boosted car do this. this is the 3rd boosted honda ive had and all had stock maps. i can try that nd see if that fixs it.
What boost levels were you running on your other boosted hondas with stock maps?
ive never had a boosted honda with a aftermarket map. im running 15 pounds. idno how the ecu messed up but i got a good deal on a ecu with the new neptune software on it so i put a basemap on it and it fixed it. im guessing some how the chip in my old ecu messed up some how. ive never had a problem running 15 pounds. i know its prolly not good for it but my last boosted civic went 2 yrs on 15 pounds all stock and the motor had 200k + on it
If you look view the options (press F4) in Crome you will see a box than says boost limit and the measurement is in mbar. Raise the number and you raise the boost limit. Just make sure your tune will support the added air flow.
it all a sudden happened. i dont drive it daily. the bottom end is built it will get a diff map and a new tune in the spring. im not worried about it if it blows it blows lol
97grnrs
Jan 9, 2008 09:57 AM
the.hamburglar
Aug 2, 2007 02:44 PM
99lspwr
Oct 24, 2003 09:12 AM
