ls vtec with pr3 pistons??
i have a question wat can i do to increase power on my ls vtec i have pr3 pistons in it wit ls rods,golden eagle sandwich oil line,gsr water pump,the head is a B17 of a 1993 gsr is stock wit aem cam gears,skunk2 manifold,b16 injectors,aem intake,...i was wondering wat can i do to it.
cams, better header, bigger exhaust, boost, etc.
the possibilities are endless. decide how much you want to spend and what kind of power you want and go from there.
You don't have p30 pistons, and you also have a pr3 head, the compression is low enough for low boost.
If you were running JDM p30 pistons and a GSR (p72) head, then the compression would be much higher and would not be ideal for boost.
You have as much compression as a GSR I believe, and it is boostable.
If you want to stick N/A, work on the head. Honda gets power through the head, I'd say cams/valvetrain first.
Boostage
Jan 16, 2009 07:59 PM
