Battery smoking & will not start after new battery, main relay, and fuel pump.
Old Nov 27, 2011 | 01:18 PM
bts_22's Avatar
Icon6 Battery smoking & will not start after new battery, main relay, and fuel pump.
I am keeping a log of this weird problem in hopes someone will help me figure out what is going on. I am not sure what else to check or where to go from here. Thanks in advance.
Normal morning... then rotten egg smell coming from the battery. Drove it for an hour parked 4 hours started it and drove another hour. Parked 5 minutes and battery died. Jump started it and noticed the battery was smoking or steaming. Drove it around 30 minutes then all the lights shutoff and the car died instantly on the highway.
-New battery but will not start dash lights weak but starter turns over strong. Seems like the fuel pump is not priming.
-Checked fuses; lots of fuses blown including ecu fuse. Seems to keep burning fuses. Main relay smells burnt so replaced. Fuel pump still not priming so replaced it.
-Still no start and fuel pump not priming. SRS fuse keeps blowing.
Old Nov 28, 2011 | 12:09 PM
bts_22's Avatar
Default Re: Battery smoking & will not start after new battery, main relay, and fuel pump.
bump
Old Nov 28, 2011 | 08:56 PM
mouab18c1's Avatar
You have a short somewhere. Check all your ground wires.
Old Nov 29, 2011 | 01:29 PM
fcm's Avatar
fcm
Old Fart
Almost sounds like batt. is connected backwards, or there is a bad short or poor main ground.
As mentioned, check your main grounds, batt. to chassis and chassis to engine, do not just eyeball the connections, remove clean both contact surfaces and reconnect.
Just in case, make sure you have the correct batt., batt. come with pos.(+) and neg.(-) posts on either side. 94
Old Nov 29, 2011 | 01:36 PM
Alexpro's Avatar
I would start looking for short, think of something you've changed in few weeks before problem started. Even replacing a bulb or fuse...
Not 100% sure but sounds like ECU ground burned up... check all the fuses, replace any relay that not look right... after all that done, try with good ECU. ECU you can get at any junk yard for like 50$
Old Nov 29, 2011 | 01:44 PM
mouab18c1's Avatar
You can find a cheaper ecu on Craigslist.
Old Nov 29, 2011 | 04:55 PM
fcm's Avatar
fcm
Old Fart
Only $33 at PicknPull. 94
Old Oct 6, 2024 | 05:54 PM
Cjh4676's Avatar
Was it the ecu?? Legit my car just did the same thing last month same fuses keep blowing i cant find a short anywhere. I can jump the fuel pump and itll run but still crank no start.
Xextr3meX
Nov 6, 2018 11:55 AM
hondagurl00
May 9, 2013 04:52 PM
sl0waccord
Mar 3, 2012 03:13 PM
alpinekllr
Jan 13, 2009 12:35 PM
b20vtecEK
Apr 5, 2005 11:45 PM
