Is this how I route the turbo piping?
Old Nov 26, 2011 | 05:22 PM
MalcolmV8's Avatar
Default Is this how I route the turbo piping?
The piping kit came with no instructions so I'm sorta guessing where stuff goes.
I think this pipe with the blow off valve flange goes here
Coming off of it I found an S shaped piece of pipe that comes down to where I'd just need a 90 degree to get to the intercooler. Although the S is to long and would have to be cut down. It's odd that it has a tube sticking out the side and a bracket that goes no where. I'm sure this was intended to go somewhere else.
Here on the driver's side I have a U shaped piece that should join to a 90 degree piece coming off the turbo. However the U shape is way to big so I'll have to cut a section out the center and then weld it back.
I also have two extra pieces you can see sitting on the ground there. The other piece under the car is exhaust down pipe, ignore that. I imagine one of the two left over 90s on the floor can be cut and made to fit on the passenger's side.
Does it look like I'm on the right track?
Old Nov 26, 2011 | 05:28 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Is this how I route the turbo piping?
no matter what you do, you will need it cut/welded for perfect fit.
if you want to do it right, u want to weld as much as u can but still be able to take everything apart if needed. Use the least amount of couplers as necessary
Old Nov 26, 2011 | 05:32 PM
Gsrsi's Avatar
maybe you inter cooler is mounted to high try n measure it up to you grill.
Old Nov 26, 2011 | 09:15 PM
MalcolmV8's Avatar
I never thought of that. Good point though, I can think of a couple joints that would be welded eliminating two joints.
No if anything the intercooler needs to be moved up a tad. When I put the bumper back it catches at the bottom and I have to really pull and stretch the bumper up to get it over.
Unfortunately my welder doesn't do aluminum very well so I'll have to take it to a local shop to get it done nicely but the trips back and forth should be worth it in the end.
Old Nov 27, 2011 | 06:21 AM
xide_12's Avatar
The "S" pipe in the second pic is the intake for the turbo, it doesnt see pressure.
At least thats how mine fit
Old Nov 27, 2011 | 06:37 AM
TheShodan's Avatar
Moderator
^^^This is correct. It is an intake pipe for a filter directly off of the turbocharger. that's why the bracket is there.
Old Nov 27, 2011 | 07:32 AM
MalcolmV8's Avatar
Ah ok. I'll need to figure out another way to get that passenger's side corner taken care of.
buck02
Jan 24, 2004 08:30 AM
PM-Performance
Jan 8, 2004 10:42 AM
-Trinitron-
Oct 3, 2003 12:25 PM
Kwuaymaikrup
Mar 30, 2003 11:27 PM
redline201
Feb 25, 2003 06:43 AM
