have a question about a eg hatch starting
Old Nov 26, 2011 | 04:50 PM
demyan's Avatar
Default have a question about a eg hatch starting
Hey i am thinking about purchasing a eg hatch shell with a d15b7 engine in it but the guy im getting it from says the engine is good but it needs a ecu, shift linkage, and axles and he has all those parts and is throwing them in. I'm just curious if i can some how test the engine out to see if it works, like does the car need all those things to start or only the ecu because if so i can tell him to install the ecu so i can turn over the engine to see if it works?
Old Nov 26, 2011 | 05:04 PM
seanbev24's Avatar
Default Re: have a question about a eg hatch starting
If you just want to see it run, the ecu is all you need (assuming the motor isn't missing anything serious).
Old Nov 26, 2011 | 05:45 PM
MidoriGreen96's Avatar
yup all you need is a ecu obd1 should work..
Old Nov 26, 2011 | 08:08 PM
Wrona's Avatar
all you need is a OBDI p06 or if its a OBD0 pm6
ki3t
105
Mar 18, 2020 11:23 AM
Jessuph Estrada
17
Oct 23, 2015 05:50 AM
eg h22
Mar 20, 2015 01:35 PM
d15Beta
Jun 30, 2003 01:27 PM
iwhichisme
Aug 17, 2002 09:21 AM
