Help with new motor
Old Nov 25, 2011 | 08:01 PM
Cd5bo's Avatar
Default Help with new motor
hey guys i just picked up a b18a1 w/ 240k. it's in good shape i got to test drive it before he pulled it out for me. well before i install it in my car. I wanna add acl bearings, ARP rod bolts, Cometic head gasket, and ARP head studs. this motor will be turbo and just deciding to add a little insurance. This is going to be my first time doing something like this it would be great for some advice and I got a few questions to ask you more experience guys. when i replace the bearings does the block needs to be send to the shop for any work or can i just remove the old one n put the new one in ? Replacing the head gaskets I no the head needs to be send to the shop to be deck anything else i should do while is there? And last question, should i replace the timing belt and water pump the previous owner said it was done about 25k ago.
Thanks, Bo
Old Nov 25, 2011 | 08:14 PM
10psiLsEf2's Avatar
Default Re: Help with new motor
Acl main and rod bearings.
Npr piston rings
Hone Block
Deck Head
Honda head gasket
Water pump
Oil pump
Arp Head Studs
Arp Mains
Valve Guides/Seals
Hondata Intake Gasket.
Timing belt.
Do it all for INSURANCE!
I did all this to my b18b1 and it runs like a champ and currently in the process of boosting her.
Old Nov 26, 2011 | 04:52 AM
grumblemarc's Avatar
The Grumpiest
Why do you not just go ahead and get new pistons and rods if you're going to do all of that?
Old Nov 26, 2011 | 11:06 PM
10psiLsEf2's Avatar
no reason too!
GSR_ITR_BOIB
Jan 14, 2019 01:42 PM
supermeister
Apr 2, 2009 04:02 AM
Evil Smile
Aug 22, 2008 11:12 PM
brandnewman16
Sep 25, 2007 07:30 AM
KevronsEG
Jan 4, 2003 09:40 AM
