92 Civic Fuse Box (in-dash)!!!!
Old Nov 22, 2011 | 03:12 AM
BobbyRodriguez's Avatar
Default 92 Civic Fuse Box (in-dash)!!!!
92 civic si hatch, Car won't get power to the fuel pump, when i start pulling fuses and mixing them around the car will do funny stuff like switch fuel pump power. I got a video... But can't upload no youtube
Old Nov 22, 2011 | 03:14 AM
Default Re: 92 Civic Fuse Box (in-dash)!!!!
What do's it mean when you put the key in the ignition and the door open the car beeps. What is that beep , where do's it come from and what is it for?
Thanks all
And when i pull the back-up light fuse right above the wiper wash fuses the car dies. The beep dies!!! 2
anyone any ideas
Old Nov 22, 2011 | 05:37 AM
grumblemarc's Avatar
The Grumpiest
It means the key is in the ignition and the door is open.
Old Nov 22, 2011 | 08:02 AM
Wrona's Avatar
Old Nov 22, 2011 | 08:57 AM
dE.fUsEd's Avatar
why are you mixing fuses?
Old Nov 22, 2011 | 08:59 AM
The Grumpiest
Trying to figure out why his fuel pump is not working. It's no kind of troubleshooting technique I've ever heard of but whatever makes him feel like he's accomplishing something.
Hope he gets them all back in the right spots.
Old Nov 22, 2011 | 09:25 AM
dE.fUsEd's Avatar
lol. serious.
Old Nov 22, 2011 | 09:26 AM
jdmcx's Avatar
did you check your main relay? probably shouln't mix around fuses ect.. just my .02
Old Nov 22, 2011 | 09:33 AM
angrysmileyface's Avatar
It the shotgun approach to returning the fuses.
Old Nov 25, 2011 | 04:13 AM
Non of the fuses blow. or brake or short or anything so the harness can't be open/jumped/re-wired.
New main relay
new dizzy
new pretty much everything... Im still lost...
Old Nov 25, 2011 | 04:30 AM
Former User's Avatar
-Double check 15A hood fuse 31 and 15A dash fuse 24 (see Electrical section of FAQs sticky for fuse box diagrams).
-Check whether the ground wire attached to the thermostat housing is clean and tight.
Old Nov 25, 2011 | 11:57 AM
jdm_2.2eg's Avatar
[QUOTE=RonJ@HT;46412052]--Check whether the ground wire attached to the thermostat housing is clean and tight.[/QUOTE]
x2
Ginpaul
Honda Civic (2001 - 2005)
Apr 26, 2018 06:02 AM
jtheshowstopppe
Jan 2, 2016 08:28 PM
Dislike
Feb 11, 2012 02:42 PM
4banger1986
Nov 26, 2008 11:13 PM
92hybridAccord
Apr 6, 2005 10:09 AM
