Oil Pressure Problem
Old Nov 21, 2011 | 10:34 AM
Steeve_Civic's Avatar
Default Oil Pressure Problem
At Idle, I have around 15-20 PSI but I have 45 PSI max on my gauge after 4000T and no VTEC, is it normal?
On my HONDATA S300 the VTS is ON (after 5000T) but the VTP is OFF?
I Disassembled the oil pan and check the the pick-up.
Do you think I need to change the oil pump?
I've never changed it, How long will it take?
What do I need change with the oil pump? any gaskets?
Engine is B18C6
Old Nov 22, 2011 | 08:21 AM
Default Re: Oil Pressure Problem
I have a "big" Oil radiator, could it be the reason of low oil pressure?
Old Nov 22, 2011 | 08:45 AM
grumblemarc's Avatar
The Grumpiest
Chances are no one knows what you are talking about when you mention VTS and VTP when it comes to Hondata. Probably since Hondata did not come standard on any Honda.
VTP seems to be VTEC pressure.
Old Nov 22, 2011 | 09:29 AM
jdmcx's Avatar
oil cooler could cause a drop in psi and also what size lines do you have running to it?
Old Nov 22, 2011 | 09:31 AM
Okay
VTS= VTEC Sensor
VTP= VTEC Pressure Sensor.
But my problem is oil pressure in the block? do you know if a oil radiator can be the problem?
Old Nov 22, 2011 | 09:51 AM
The Grumpiest
Old Nov 22, 2011 | 09:55 AM
8AN I think.
Old Nov 22, 2011 | 10:31 PM
it is bigger than 8 AN 10 or 12AN
PH3593A
11
Jul 19, 2023 02:36 AM
JDMCIVIC919
Jan 20, 2012 01:21 PM
DC2TEGGA-GSR
Jan 19, 2006 05:04 PM
boost'dsiR
Jul 20, 2005 02:44 PM
toooslow
Oct 19, 2003 04:05 PM
