My B16T setup :)
Hey all
I have a 95 civic coupe(ej2) with a 2nd Gen JDM b16
Ive been reading alot of boost builds and id like to show mine aswell so here goes ,my aim is in the mid 300whp range and i will also be running 94octane.thanks in advance guys!!
Here's the setup(on what i have)
-Skunk2 pro1's
-Skunk2 pro adj cam gears
-Skunk2 valve's and springs
-DC2 Intake manifold
-Tial 38MM wastegate
-Tial Q BOV
-GM 3bar map sensor
-ARP headstuds
-Stiffer motor mounts
-SPAL slim fan
-Journal ball bearing GT28 .65AR
-Mishimoto Rad
-Mishimoto fan switch
-Precision 650cc injectors
-Walbro 255
Left to buy or be done
-Piston,Rings and rods
-Oil squirter block offs
-Custom piping
-Intercooler(not sure on the size as of yet)
-Will be having the block refreshed before new components are installed
-OEM headgasket
-Clutch(possibly a stage4 not sur eon the company)
-LSD
-DSS axles
-Also i will not be sleeving my block this year because i will not be able to afford it and i wanna enjoy be able to run my setup next summer.
-Skunk2 pro1's
-Tial Q BOV
-GM 3bar map sensor
-ARP headstuds
-SPAL slim fan
-Mishimoto Rad
-Walbro 255
-Custom piping
-OEM headgasket
-LSD
-DSS axles
well i still have my stock SiR cams but would it be a good idea to to keep the intake pro1 cam n get a GsR exhaust cam, seeing as the intake cam is similar to the type R cam?
and i had also have those cams because i did head work earlier in the year and decided to stick with all motor but then i experienced a boost gsr this summer n i slapped myself and said why am i wasting m money on NA
Keep the oil squirter to unless you have to get rid of them from clearance issues. A jet of oil spraying up onto the piston crown beats any so called tuning tricks in cooling piston crown temps.
Sell off the Pro1s., get CTRs or GS-Rs. Unless you're running a larger mid-framed sized turbo (GT35R or larger), you're actually going to lose power.
thanks alot all of your opinions are greatly appreciated, i may or may not pull the cams this week cuz its starting to get real cold in montreal nowadays and i dont have a garage to work, aside from my drive way
For 300whp stock b16 cams will be more than enough, even for that smaller turbo. People have done 400whp with bone-stock b18c1's on pump gas. You can keep them for the time being, but I'd suggest pulling them out soon. The best thing to do is to build the bottom end, get the motor running, then upgrade the head later.
FYI if you don't plan to ever go much higher in power, get some 10:1 pistons. Otherwise 9:1 would let you grow later down the road. 10:1 is a better option for power only if you have big cams, and 8:1 is only needed on crazy builds and DSM's.
I agree a set of GSR cams work well with a mild boost set up and are a set up from B16 cams. Many people report a faster spool and more low end with GSR cams. I am going to swap to GSR cams I think when I put a turbo on my LS Vtec. CTR have been seen to make very good gains with a turbo set up, if you can find some at that is the best way to go. And yeah keep the oil squirters they will help decrease pistons temps big time, very important when boosting.
js9771947
Feb 28, 2012 07:23 PM
imationdawg
Nov 13, 2010 04:58 PM
