car wont start after head gasket install
Old Nov 19, 2011 | 09:25 AM
rj520's Avatar
Default car wont start after head gasket install
1996 Civic EX 160000
completely stock
automatic
Hello, I'll try to sum up as concisely as possible.
Head gasket had a leak
had a machine shop mill the head
Just finished reinstalling
Engine started for about 5-10 seconds.
Shut off on its own.
Checked timing by setting TDC on cam gears, and Crank pulley
Tried to start again, wont restart
any ideas?
thank you
Old Nov 19, 2011 | 10:04 AM
delsolo95's Avatar
Default Re: car wont start after head gasket install
check timing and spark plug firing order
Old Nov 19, 2011 | 11:59 AM
Wrona's Avatar
check compression
Old Nov 19, 2011 | 12:03 PM
rj520's Avatar
Thank you very much for the suggestions. It appears I do not have spark at all. The in cab #9 fuse was blown, replaced it, still nothing. Removed the distributer cap, tested the coil. It tested 0 ohm resistance between the two primaries meaning it failed. Off to buy. New one and go from there.
Any ideas why that might happen? I'm just guessing its my kinda luck
Old Nov 19, 2011 | 01:27 PM
rj520's Avatar
Replaced the ignition coil, still no spark
Old Nov 19, 2011 | 02:57 PM
rj520's Avatar
No progress. I've gone through every test in the haynes manual, its getting power through the harness to the blk/ylw and bl/wht wires. I suppose the next thing according to the haynes is a new ICM?
i dont suppose anyone has any other ideas what i might have missed? such as downer after having completed my first head gasket install by myself to run into this problem.
any help would be appreciated.
thanks
Old Nov 19, 2011 | 03:21 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Make sure the ground on the thermostat housing is on and tight - G101:
Old Nov 19, 2011 | 03:25 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Test the new coil just to be sure. If it's an aftermarket coil it could be bad out of the box.
Old Nov 19, 2011 | 03:54 PM
Former User's Avatar
Does the fuel pump prime? Did the timing belt snap or strip?
Old Nov 19, 2011 | 10:08 PM
apexi_rsx's Avatar
how much was the head milled? did you use a adjustable cam gear?
deepfriedjinx
Aug 26, 2024 01:01 AM
CD0419
Honda Civic (2001 - 2005)
Oct 21, 2017 09:23 PM
dcomer04
May 14, 2008 07:50 AM
bigdieseltbc
Jul 16, 2007 09:36 PM
Red93AWD
10
Aug 16, 2005 06:45 PM
