Right headlight Low/Hi not working
o4 Civic the right headlight Low/Hi not working. I changed the bulbs not blown, fuse & relay changed no luck The wiring look good. Could it be the turn signal switch??
I forgot to mention that I have a DRL (day time running light) flash every now and then on the dash and apperantly this will effect the head lights. This module is around $200 I found a fix on you tube
http://www.youtube.com/watch?v=PmsAt...eature=related
Techvegas
Dec 12, 2019 10:00 AM
humantorch700
Jul 21, 2018 03:12 AM
