Help!! I'm having problems installing my drag turbo kit
I got a couple of things that I had a problem with. When trying to install The first is how to run the power wires for the vortech inline fuel pump? How did you run the obd sensor to the down pipe? How do you put on the tial waste gate (how do you connect all the hoses?
1. tap the power wire of the inline to the power wire of your stock pump.
2. The dp has to be custom fitted to your exhaust. A muffler shop will hook you up.
3. Side port of wg goes to a vacuum source. Top is for boost controller.
btrim23
Feb 18, 2004 04:43 PM
chuckd05
Oct 16, 2001 09:43 AM
