Help!! I'm having problems installing my drag turbo kit
I got a couple of things that I had a problem with. When trying to install The first is how to run the power wires for the vortech inline fuel pump? How did you run the obd sensor to the down pipe? How do you put on the tial waste gate (how do you connect all the hoses?
Re: Help!! I'm having problems installing my drag turbo kit (dragtaccord)
1. tap the power wire of the inline to the power wire of your stock pump.
2. The dp has to be custom fitted to your exhaust. A muffler shop will hook you up.
3. Side port of wg goes to a vacuum source. Top is for boost controller.
Re: Help!! I'm having problems installing my drag turbo kit (speedymon)
Re: Help!! I'm having problems installing my drag turbo kit (MyWhiteCivic)
You'll only use the top port if you have an electronic boost controller. Otherwise leave it open.
Re: Help!! I'm having problems installing my drag turbo kit (Etylorcen)
Whups....thank you for correcting me. So if i have a manual boost controller it goes on the side port in place of the boost reference?
btrim23
02-18-2004 04:43 PM
chuckd05
10-16-2001 09:43 AM
