98 civic ex solenoid valve and oil pressure switch.
Old Nov 15, 2011 | 02:55 PM
LoGaN-VanG's Avatar
Default 98 civic ex solenoid valve and oil pressure switch.
I need help with my solenoid, my check light engine is on which is the oil pressure switch. now I didn't change it yet but I wanna know if that's what cost it to leak oil from my solenoid. Cause I just replace a new gasket on my solenoid. idk I'm lost pelase help...
Old Nov 17, 2011 | 09:48 PM
BaronvonOttobat's Avatar
Default Re: 98 civic ex solenoid valve and oil pressure switch.
So you've hooked up a scan tool and the only cel code is for your pressure sensor?
Old Nov 18, 2011 | 07:19 AM
motegicivic's Avatar
Are you asking if that is causing your leak on the vtec spool valve?
The oil pressure switch can leak a little oil, but most of the leak will be from valve to the engine.
Old Nov 19, 2011 | 11:50 PM
LoGaN-VanG's Avatar
No, I jump the connector, and it's 22 which is the oil pressure switch... I replace now it's gone but... oil is leaking from the solenoid, looks like from the block and the solenoid...
Old Nov 19, 2011 | 11:53 PM
LoGaN-VanG's Avatar
your saying from the block and the solenoid? I don't get it... is this a major problem to work on? cause freaking oil keep leaking from the back side where the solenoid is and it's all over my transmission and block and under it. please help....
Old Nov 20, 2011 | 09:51 AM
This is simple, there are 3 bolts, you will see them on the side of the spool valve, take them off, remove the valve, you will see a 3 hole gasket like a snowman, peel it off, put on the new one, fits one way, reinstall, do not go crazy tighten it.
Old Nov 25, 2011 | 09:27 AM
LoGaN-VanG's Avatar
DAM, I think I went a little crazy on the tight. OMG. :/ freaking oil is all over my transmission. FML
gotta get a new gasket then huhh? let me know please.
Old Nov 25, 2011 | 02:38 PM
Did you get a new gasket and tried to install it and you think you went too tight?
Do not tighten too too much you can crack the spool valve.
Old Nov 25, 2011 | 02:49 PM
LoGaN-VanG's Avatar
yeah I got a new gasket for it, but I think I over tighten it. First thing I kinda work my way around it, softly and then and little more and I keep going around but then I tighten to were it can't move anymore. Which I think I super tight it, :/
Ryaajus
Oct 16, 2019 08:45 AM
Cameron707
Aug 21, 2015 10:00 PM
ZooKs
Apr 25, 2010 11:24 PM
missionaryrider
Dec 9, 2007 01:50 AM
scarecrow
Mar 7, 2005 10:26 AM
