Replace oil pressure switch
Re: Replace oil pressure switch
P2648 VTEC Solenoid Valve Circuit Low Voltage
Disconnect the VTEC solenoid connector and measure resistance between the valve side of the connector and the valve body. If not between 14-30 ohms then replace the solenoid. If the solenoid is good then you have a short between the solenoid and the ECM/PCM.
LoGaN-VanG
11-25-2011 02:49 PM
