12.9-12.5V system voltage with engine running
Old Nov 13, 2011 | 08:38 AM
v.i.gsr's Avatar
Default 12.9-12.5V system voltage with engine running
I have a question for you guys. With your tuck harnesses, what kind of system voltage are you guys seeing with your harnesses.. I have a chasebays cm2 harness, and I think the alternator wire for the harness may be to small.. I'm seeing about 12.9-12.5 and even 12.0-11.7 sometimes with my accessories on(stereo, fogs, and headlights).. The voltage is supposed to be around 14.0-13.8, with the car running..
I changed my alternator already, due to the voltage regulator going bad and the system was being overcharged.. I replaced my battery also, just wanted to see what kind of voltage you guys were seeing with your tuck harness..
Old Nov 13, 2011 | 11:48 AM
Former User's Avatar
Default Re: system voltage
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Nov 13, 2011 | 01:22 PM
v.i.gsr's Avatar
96 cx hb with gsr swap chasebays cm2 harness(obd1),obd1 alternator.. P28 hondata ecu
Old Nov 13, 2011 | 02:11 PM
Title changed to summarize tech problem.
Have you checked whether fuse 15 is blown?
When you turn the key to ON(II), does the charge system warning light in the cluster turn on?
Old Nov 13, 2011 | 02:44 PM
apexi_rsx's Avatar
Default Re: 12.9-12.5V system voltage with engine running
mine charges the same as stock with my tucked harness u must have a problem. the alternator wire goes straight to the fuse box. trace your wires and check it out.
Old Nov 13, 2011 | 03:01 PM
v.i.gsr's Avatar
I checked fuse 15 already, and its good..
Old Nov 13, 2011 | 03:16 PM
Does the charge system light turn on?
Old Nov 13, 2011 | 05:11 PM
v.i.gsr's Avatar
Doesn't turn on...
Old Nov 13, 2011 | 05:13 PM
That's a problem. Turn the key to ON(II) and check whether both top test tabs of fuse 15 have battery voltage to body ground.
Old Nov 13, 2011 | 05:36 PM
v.i.gsr's Avatar
I forgot to mension that I have the altc dissabled in my hondata.. Also my eld is dissabled
Dont know if that would make a difference...
Old Nov 13, 2011 | 05:49 PM
The fact that the charge light does not turn on suggests that the alternator is not getting voltage from fuse 15. If so, the alternator won't charge.
v.i.gsr
Nov 13, 2011 05:15 PM
xxbvanxx
May 18, 2010 11:25 PM
dilp112
12
Nov 7, 2007 02:52 PM
HybridHatchC1
Feb 8, 2005 04:26 AM
