2000 civic coupe aftermarket (ebay) foglight help
Old Nov 10, 2011 | 05:43 PM
rawrjaay's Avatar
Default 2000 civic coupe aftermarket (ebay) foglight help
So i just bought these foglights like a month or so ago
and all of a sudden my friend thought he seen the foglight pop or flash so he walked over by it and said that its not working
so i put the other foglight from the opposite side on the side that does not work, and the foglight worked
so i took the foglight off the bumper, and i wanted to no if i could just replace the foglight bulb? instead of having to buy foglights all over again..
because the bulb also looks like it is connected to a freaking wire?
idk im so confused
Old Nov 10, 2011 | 05:52 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 2000 civic coupe aftermarket (ebay) foglight help
The bulb is connected to a freakin wire? What else would it be connected to? Did YOU install it? How do you NOT know how it's connected? Change the damn bulb.
Old Nov 10, 2011 | 05:59 PM
rawrjaay's Avatar
grumble u *******! i cant change the bulb because the BULB itself is connected to a damn wire! watch check this out man:
and NOW the freaking bulb pulled off the damn wire and is completely disconnected
Old Nov 10, 2011 | 06:05 PM
The Grumpiest
Next time buy OEM. None of those Ebay kits are made the same. I have a Depo set and the bulb isn't connected to a freakin wire. Normally a bulb plugs into a socket. At least on MY planet it does.
I bet you bought them used.
Old Nov 10, 2011 | 06:06 PM
98civdx's Avatar
Master Detailer
This is why you DON'T BUY EBAY CRAP!!!!!!!!!!
Unless you can figure out a way to replace the bulbs, your going to buying new lights.
Old Nov 10, 2011 | 06:40 PM
rawrjaay's Avatar
no i DID NOT buy them used
and im trying to figure out a way to replace the bulb but i have no idea why that freaking bulb looks sodered to the damn wires...
Old Nov 10, 2011 | 06:46 PM
Wrona's Avatar
because its an H3 Bulb read the bulb next time
they cost 13 dollars each from sylvania from autoparts store
Old Nov 10, 2011 | 06:49 PM
The Grumpiest
I will say that I have never had to deal with an H3 bulb but it is apparent looking that the photo that it is able to be disconnected. I've never seen anyone have this much difficulty unplugging a bulb.
Old Nov 10, 2011 | 06:52 PM
Wrona's Avatar
lol have you not seen his previous posts im sorry but this guy isnt the brightest
he even started a WTB thread in the market place
Originally Posted by rawrjaay
I need a depo or aftermarket foglight because of mine blew out
because he doesnt know how to disconnect the bulb and bring it to a parts store or even read the stamp that says H3 on the bulb
Old Nov 10, 2011 | 07:02 PM
rawrjaay's Avatar
well thank you for seeing that, but the thing is the wire that is white connects through the main wire that i plug into the harness....
get me? or no? im not sure if i explained it right
Old Nov 10, 2011 | 07:05 PM
The Grumpiest
Better pics.
HondaMizzan
Lighting
Mar 16, 2015 08:18 AM
MMMGIRL
14
Jun 6, 2012 11:44 PM
SphiNX912
Sep 11, 2006 04:03 PM
senpai
Apr 9, 2004 09:34 AM
ceLtic
Feb 2, 2004 06:23 PM
