Car overheating help
Old Nov 10, 2011 | 10:18 AM
jdmchickx's Avatar
Default Car overheating help
Was dealing with an idle problem cleaned the iacv and fitv now the idle is normal and doesn't fluctuate. Also replace coolant lines running into iacv.
Finally let the car get up to temperature an drove it and the car started
Overheating the temp gauge was all the way up to hot.
Any ideas/suggestions?
Old Nov 10, 2011 | 10:39 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Car overheating help
Same as every other overheating thread.
Air in system? Fan actually working? Replace thermostat?
Old Nov 10, 2011 | 11:06 AM
mcorley187's Avatar
Also what motor do you have? I have a b16 in my hatch and I had a overheating problem and I had to get a bigger radiator. Still had a lil overheating pro lem and got a slim fan, which pulls or pushes more air than factory, and that did the trick. Hope it helps u out
Old Nov 10, 2011 | 11:59 AM
jdmchickx's Avatar
Im guessing and hoping it has something to do with coolant. The coolant lines and coolant was ****ed with a lot during this process.
But I'm just trying to get some more input
Old Nov 10, 2011 | 12:25 PM
quick86's Avatar
Sounds like air in the system. Did you burp the cooling system? I use this:
http://www.amazon.com/Lisle-24610-Sp.../dp/B001A4EAV0
It's a great product. Fill the funnel with coolant and run the car. As it expands it's also creates a high point for air to escape the motor/radiator/hoses/etc etc etc.... And when you're done, stick the plug in the funnel, and empty it back in the coolant bottle for use at a future time... I've found this is the BEST way to ensure ALL air has been removed from a cooling system.
Old Nov 10, 2011 | 12:59 PM
toytech116's Avatar
it also may help to park on a hill when burping the coolant system
PaulMc
Feb 20, 2014 09:43 PM
josephcmiller2
Engine Management and Tuning
20
Aug 1, 2011 06:05 PM
LeArN2LiVe
Nov 22, 2008 12:08 PM
bitr364
Jul 22, 2003 02:03 PM
spart
Feb 27, 2002 05:31 PM
