e-brake adjustment woes
my parking break is half-assed at the moment...when i engage it the car still slowly creeps forward (at about half the normal speed it would idle forward without the brake engaged)
so i take the console off and go to adjust the bolt AND ITS STRIPPED...i can get a little bit of tension but then it slips back down to where it was.
this is no good, because i cant jack up my car without the e-brake engaged (safely)
if i replace the whole handle/springloaded bolt mechanism...how do i get the cables off the old bolt and onto the new ones? i will try to get some pics up, but there's really nothing to look at. i need about another 1/4inch of play on that adjustment bolt to get the grip i need from the rear brakes.
any info you can provide would be helpful. thanks for reading.
You can still safely jack a vehicle up by using wheel chocks.
What year, and sub model of Accord do you have? Dis or Drum rear brakes?
Have you checked with Majestic Honda parts section online?
i suppose it is possible that someone over tightened the cables...but that person definitely was not me.
97 LX /CD7 (rear drums)
have not checked majestic yet. the threads that i can see dont look damaged...but the bolt acts like its going to tighten up and then slides right back to the end. there is minimal bite, i would say.
there is play, just not enough.
i took apart the parking break assembly and made sure the adjusting nut wasnt stripped. tightened it all back up and they e-brake has proper bite now.
the real problem is that the rear brakes are prolly shot. no sweat.
VTAC-KAT
11
Nov 2, 2006 03:19 PM
