can someone give me some advices about tig welding
So heres the thing, i bought a tig welder about a month ago, so im still learning, and im solving my issues step by step, but i cant figure out why is this happening to me.... my welds look like swiss cheese from time to time and sometimes they look "grainy" anybody has an idea
all of the welds were made with same settings, no filler, but i dont know amperage since i was using the pedal id say around 120A, material is 4mm steel.
first and second weld, look awful, espescially second and third looks decent i guess:S
P.s:excuse my english its not my native language
We need more Information in order to help you out!
What Kind of Welder are you using?
What kind of Tungsten are you using?
What setting do you have on the gas?
Information like that..
You can also check out WeldingTipsAndTricks.com for allot of info.. I always look there..
i used TIG method, basically just melting two pieces together
i clened both pieces with flap disc prior welding, but it might be that was not enough. ill train and try to improve, thanks to everybody wjo took the time and tried to help
could also be gas coverage since im using cup #5 and it seems really small to me.
go to your local metal supermarket and get some clean fresh metal to practice. they should have a ton of little odds and ends that they will either give you, or sell for nearly nothing.
beats trying to clean old metal to practice.
azfab1031
Welding / Fabrication
16
Dec 21, 2004 12:37 PM
Amuse9
Oct 26, 2002 07:18 PM
