Intake Air Temp sensor causing stalling?
Old Nov 8, 2011 | 01:31 PM
CaptivaBlueTeg's Avatar
Default Intake Air Temp sensor causing stalling?
I have a 2003 Rsx type s. boosted with the greddy kit and tuned on k-pro.
For some reason the car started to act funny and stall after it was warmed up and at a stop. After doing some "diagnostic" test such as, spark plugs, compression, coil packs I found nothing wrong.
Then while doing other stuff I took off my intake and forgot to plug my iat back in. Havent had a problem since doing that. I drove for about a month with it unplugged and never stalled. I ordered a brand new oem Honda iat and as soon as I did that I got the same problem.
What else could be causing the stalling. Sometimes it's when I slow down to a stop, and I've had one dangerous moment where it did it around a corner causing loss in power steering.
What else would cause this? I've had the tune for over a year before it started doing this.
Old Nov 9, 2011 | 05:39 AM
dacowgod's Avatar
Default Re: Intake Air Temp sensor causing stalling?
Mine used to have erratic idle and stalling issue.. that would come and go... it ended up being a dirty throttle body... just a thought..
Old Nov 9, 2011 | 06:14 AM
turboteg2nv's Avatar
Clean your IACV. This eliminates a lot of problems with idle, especially when using Kpro.
Where is your IAT installed now? Does the sensor push out of the hole under boost?
Old Nov 9, 2011 | 06:36 AM
Iat is right behind the greddy air filter. Nope, doesn't pop out during boost.
I forgot to mention, I cleaned the iacv and throttle body when the problem first started. My idle isn't very eratic, stays a constant 950. Every now and then it will jump around but only once and go back to 950.
I've adjusted idle and iacv slider in kpro, i even tightened throttle cable. Still the same problem.
Only thing I can think of is the cam sensor, but after blowing $30 on the iat I don't want to just replace parts that are still good. I know the cams stay at 0 with the iat unplugged from what kpro data log shows.
another interesting thing about it is, it really only happens when I drive the car and shut it off to go to a store. Once I do that all hell breaks loose and starts the stalling issue.
Old Nov 12, 2011 | 08:41 PM
Bump, put some more oil in, it helped but will still stall. Vtec oil switch??? Lol I have no idea
Old Nov 13, 2011 | 10:05 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
IAT won't cause any idle or stalling issues. At least not in my experience and I drove boosted without one many of times (long story)
You can adjust your IACV in kpro. I've needed to do that. You might just need to do the same thing.
Old Nov 13, 2011 | 01:46 PM
Already adjusted it in kpro. Even raised the idle. Quite a few times actually. But that's the thing, it never stalls with it unplugged. But it will with it plugged in. I guess my question really is, what does the iat sensor affect that could be related, like is another sensor affected by what the iat says and thats the sensor that is bad?
9thgenidiot
Mar 10, 2025 08:37 PM
hondan00b95
Jul 24, 2014 12:57 PM
dolbo74
Sep 14, 2008 03:35 PM
turbotime
Jul 12, 2003 06:11 PM
Fly1865
Mar 31, 2003 11:24 AM
