T3/T4 T04E Q
How much HP would I be making running 6-8 pounds of boost on an h22 with a t3/t4 .57 trim?
I want to make a decent amount of power if I'm going to invest in going FI, if not I'll just save the money and build something else.
If you plan to boost a H22 I would sleeve it to get rid of the FMR liners in the cylinders, they are not to boost friendly. 6-8lbs around 250-300 depending on setup and tuning. There is not no exact answer to your question as each motor and turbo system is different.
IME FMR liners cause blow by as the liners and rings wear. I have seen stock H22's burn oil. They are not weak never said that I have seen 12psi daily driven with 15psi at the track on FMR liners, but the motor was healthy and young. They just tend to wear out a little faster that a normal sleeve and you get oil burning and some blow by, not good things for a boosted motor.
The liners have absolutely nothing to do with boost-friendlyness.
